trailer axle springs or tors. axles
please shed some light on which is better and why? pro's and cons and this trailer is used in salt water, so i know springs rust but not sure if ones better than the other, looking at phoenix and hi-tech! please help!
Torsion springs tend to work where as leaf rely on each other to work. As you go over a bump, the torsion system will go over it smoothly verses the leaf that transfer the weight to the other spring next to it. Also in a braking situation, all the brakes will work the same verses the leaf spring system tends to roll or lift the other axles.
Registered User
Torsion axles aren't without their own issues. They can be loud- squeking constantly with no way to make them stop. If you have roadside issues, you're in deep. With leaf springs, they can be fixed with readily available parts in most cities. If you snap a spring, it can be bunked up and nursed off the road.
Just another Toy
15
03-11-2008 06:15 PM
