Ford Recall
Everything is for sale @ a certain $$
I just checked my vin and mine is under recall
Here is a link to fords site you just have to put in your vin
http://www.ford.com/owner-services/c...ll-information
CYA by Ford. You put a recall out on an item, it may help you in the eyes of the courts if there are lawsuits due to accident, fatalities, etc. The original CPS's were pure junk and have been a common problem for a long time. It can be a handful if one fails at speed pulling a load. Luckily, they rarely fail that way, giving intermittent problems i.e. no start, dying after starting etc. prior to failure. Replacements used to be well over $100, the new ones of improved design and from a different vendor (the one you will get installed when showing up at your Ford dealer for this recall) are about $25. I haven't had one fail, but I keep one in my glovebox- not at all hard to change on the road if needed. It's still a great engine with incredible reliability. IMHO, the recall is long overdue.
And yes, vendor swap fixed the failures.
BLee
26
10-23-2005 06:50 PM
boot
08-16-2002 11:06 AM
