08' Cadillac Escalade ESV tow vehicle? >
Old 03-17-2008 | 09:45 AM
Default 08' Cadillac Escalade ESV tow vehicle?
Anybody have experience towing with Escalade ESV? Would like to know if capable of towing Cig Mistress using Myco dual axle...
concerned with tongue weight...
bootdaddy is offline
Old 03-17-2008 | 09:57 AM
seafordguy's Avatar
No experience, but judging from the weight of My Cafe Racer, I don't think I would want to be towing that Mistress on a Dual Axle Trailer with ANY Cadillac....
seafordguy is offline
Old 03-17-2008 | 09:58 AM
cigrocket's Avatar
I don't have the escalade but I do have the mistress. And I would say with fuel, trailer and boat. It ways about 14,000 lbs. I pull it with a dodge dually. I don't even think the escalade has a 9000 lb rating. You would not be able to stop safetly.
cigrocket is offline
Old 03-17-2008 | 10:06 AM
seafordguy's Avatar
I couldn't find a rating on the '08's, but the prior years were in the 7k range. That is far short of 14k...... Especially when you are trying to slow down.
Old 03-17-2008 | 10:12 AM
I found 10,500 lb rating on Caddy and was not sure of Mistress weight...sure seems like a no-no
Old 03-17-2008 | 10:14 AM
socalstone's Avatar
7900lb towing if it's 2 wheel drive.
7800lb for the all-wheel drive.
Don't have spec for tongue weight- but would guess 500-600lbs.
socalstone is offline
Old 03-17-2008 | 10:19 AM
yup...my bad, was thinkinh tundra specs
Old 03-17-2008 | 10:47 AM
Sydwayz's Avatar
Forum Regulator
DEFINITELY not going to work.
Sydwayz is offline
Old 03-17-2008 | 11:28 AM
cigrocket's Avatar
I know a guy who tows his mistress with a 2500HD avalanche 8.1 . I know he is over the limit, he does have heavy duty brakes and air bags, but he knows if he is in an accident that he will be on the chopping block. Safer with a 3500 something.
Old 03-17-2008 | 11:48 AM
Sydwayz's Avatar
Forum Regulator
That truck is actually rated for 12,000 to 12,5000 lbs. towing depending on which year it is. It does an adequate job at such, but obviously overkill is better.
The Cadillac Escalade EXT is the Avalanche derivative, based on a 1500 Avalanche. The Cadillac Escalade ESV is Suburban 1500 based.
Sydwayz is offline
