Need More Mpg 2007 Duramax Dully >
Old 06-27-2008 | 11:11 PM
Hot Duck's Avatar
Originally Posted by Quicksilver
DPF and regen is what is killing the new trucks mileage.
I wish I knew how to get rid of the DPF without tripping computer codes. Any ideas? Can it be done?
Hot Duck is offline
Old 06-28-2008 | 12:20 AM
Hey Mr.Gris! Thats pretty funny! When you blow the engine in your truck and you need my help to get it covered under the warranty, don't call me. I'll be busy laughing my a$$ off at you!
Sorry.............couldn't help it!
Speedpro1 is offline
Old 06-28-2008 | 05:28 AM
they get unbelievable mileage sitting at the dealer tied up in litigation getting pounded by hailstones...
Rippem is offline
Old 06-28-2008 | 08:32 AM
Innocent jab........settle down.
FWIW - my '03 LB7 runs just fine at 145k. Good luck getting a new motor.
Griswald is offline
Old 06-28-2008 | 11:16 AM
At least I haven't had to buy diesel lately!
Old 06-28-2008 | 11:17 AM
No problem! I'm still laughing!
Old 06-28-2008 | 11:27 AM
FASTTIMES's Avatar
HotDuck,
On the 6.4's most guys are running the Spartan Diesel Tech setup - - DPF delete, 3 custom tunes, Dashdaq for monitoring and claiming up to 6mpg's better stock. I don't have a DPF setup yet, but its tempting. I'm sure there are guys doing to same for the new DMAX.
http://www.thedieselgarage.com/forum...play.php?f=162
FASTTIMES is offline
Old 06-28-2008 | 11:45 AM
Originally Posted by FASTTIMES
HotDuck,
The new LMM DMAX will show it has been played with in the computer. i am sure over time someone will find a way around it. The exhaust has around 6 sensors pluged into it. It is common from most of the sites I keep track of that the mpg's su#k on the new trucks with all the polution stuff on them.
Old 06-28-2008 | 08:50 PM
go to the dieselplace.com ,theres a computer programming software kit,you use that to bypass the dpf system and put in a regular exhaust system,but keep your stock exhaust sys,its worth $5,000-7,000
dmaxx3500 is offline
Old 06-29-2008 | 12:27 AM
Strip Poker 388's Avatar
Rob
stock exhaust???????? I took mine off without even cutting it,Complete, whats it worth
Attached Thumbnails Need More Mpg 2007 Duramax Dully-exhaust-002-medium-.jpg
Strip Poker 388 is offline
