Polishing an aluminum trailer
Old 04-21-2009, 02:42 PM
I know everyone wants a shiny trailer but you are taking off the aluminum oxide. The oxide will form again and in fact it is the oxide that protects the aluminum from further oxidation. I would leave it alone or paint it.
Padraig is offline
Old 04-22-2009, 08:04 AM
rv
One thing that helps keep it shiny is to coat it with Leverage sealant.
rv is offline
Old 04-22-2009, 10:29 AM
Jassman's Avatar
Originally Posted by rv
One thing that helps keep it shiny is to coat it with Leverage selant.
Thanks RV, I forgot to mention that...Ya, I just pour it on there by the gallons guys...Just kidding..spray on towel and do like you do on the boat.
Jassman is offline
Old 04-23-2009, 02:32 PM
Rob
Strip Poker 388's Avatar
does it turn white in the grain?
Strip Poker 388 is offline
Old 04-23-2009, 03:58 PM
Jassman's Avatar
Sam has been applying with towel, which turns grey, then he brillo pads the remaining product while using water. It's a half way of doing it but it looks much better and takes have the time. No buffer..no acid, completely safe. He has been working on the boat all day.. trailer, boat and cabin looks awesome. Check the shine on the hullsides...Jeff
Attached Thumbnails Polishing an aluminum trailer-leverage-blue-bayou-001.jpg   Polishing an aluminum trailer-leverage-blue-bayou-002.jpg   Polishing an aluminum trailer-leverage-blue-bayou-003.jpg
Polishing an aluminum trailer-leverage-blue-bayou-004.jpg   Polishing an aluminum trailer-leverage-blue-bayou-006.jpg
Jassman is offline
Old 04-24-2009, 07:31 AM
rv
Strip,
No the sealant doesn't turn white in the grain. As Jeff mentioned, spray on rag and wipe on trailer. I do not rub to much with the rag. If you rub alot it will start to turn grey/polish. Just put enough on, let it dry and buff it off. Looks good, still has the satin look of the brushed metal and it protects it from water spots. However, I do wipe the trailer down when I can after pulling from the water.
I have tried other products, including 3m liquid wax and they start to polish the trailer and will leave it looking like you did a half a** job.
On the prep side I use AlumBrite, it is an acid. You need to make sure you wet other areas down and rinse the treating surface good. However, it is less work and does a nice job of giving that new aluminum look. You have to remember this is brushed alum and will not shine like polished alum.
Rick
rv is offline
Strip Poker 388
03-26-2006 10:55 AM
Strip Poker 388
6
02-08-2006 12:41 PM
HiPerf2000
13
11-08-2004 12:21 PM
Intolerant1
04-15-2002 07:03 PM
Quick Reply: Polishing an aluminum trailer
