Another Trailer Brake Situation
Doesn't seem bad at all. Did you already have the brake controller or do you have an in-vehicle on that was compatible?
Still thought would be much higher $$$$ , pretty cheap for what you get.
I switched my surge drum to just plain electric drum on my 29 fever . they work great . it is cheap because all you need is new backing plates with the shoes and magnets for about $50 a wheel . weld the coupler solid and you probly already have a brake controler in your truck . that is all you need . I would not use this setup in salt water .
