Dually Tires
Old 05-12-2009 | 09:46 AM
Default Dually Tires
Any suggestions for a LT225/75-16 or a LT235/75-16? I want a smooth sidewall and non aggressive tread for a slammed 2wd dually
kennyo is offline
Old 05-12-2009 | 12:16 PM
MICHELIN ,,,they'r the best and softest ride !!!
DareDevil is offline
Old 05-12-2009 | 03:11 PM
From: A tree somewhere in the woods in Clarcona Fl.
Ditto, pricey, but ya get what ya pay for, look at the 245/75R16's.
Slick02 is offline
Old 05-13-2009 | 05:54 AM
mama tryed's Avatar
Kenny are you sure a 75 ratio will work? most are 85
mama tryed is offline
Old 05-13-2009 | 06:02 AM
offshoredrillin's Avatar
I've got toyos on my slammed dually and it rides like a dream, I have 19.5's though. I have close to 70 k miles on the rear ones and they ride perfect. I put new drive tires on every 2 years because they cup from me running them a little under inflated.
offshoredrillin is offline
Old 05-13-2009 | 06:19 AM
Croozin2's Avatar
If it's a 90's model GM then it came with 225/75R16'S. I went through the original Generals, then Goodyear Wrangler HT and finally Michelin. The Mich's are by far a superior tire to all the others I tried. Better wear and ride like a dream.
As far as going with 245's, they probably won't work. Was debating it on my old dually but there wasn't enough clearance between the rear tires. You could create a very dangerous situation.
Croozin2 is offline
Old 05-13-2009 | 08:10 PM
Formulabill's Avatar
Michelin LTX/ MS use the 235s and you will not need spacers.
Formulabill is offline
Old 05-13-2009 | 10:53 PM
The OEM Generals lasted just 41,000 miles on my 2006 Dodge dually. I switched to Michelin LTX M&S. Great ride and handling, plus no noise.
Catmando is offline
Old 05-14-2009 | 06:19 AM
Chuck's Avatar
Are the Michelin LTX series available in the 19.5" for the F-450's?
Chuck is offline
Old 05-14-2009 | 07:00 AM
Croozin2's Avatar
I'll let you know later today Chuck. I am looking into replacements for my 450 as well. I own a tire and car care center so I'll do a little digging and let you know what I come up with.
Croozin2 is offline
