Tie Downs/ Straps
Old 10-01-2009 | 12:14 AM
Default Tie Downs/ Straps
I know at one time Sydwayz or someone posted a link to a place with good tie down straps. This fall I am going to replace my tie down straps for the boat and would prefer not to have so much extra webbing as the current set up. Currently I am just using some 15k 3" webbing ratchet straps but they are like 15' long and I have to use duct tape so the extra webbing isn't flapping in the wind. Also, does anybody use cable rather than webbing on the their winch strap? I was thinking cable might be more "static".
Thanks..
baywatch is offline
Old 10-01-2009 | 12:21 AM
Sean H's Avatar
A to Z
http://www.macscustomtiedowns.com/category/TieDowns
Sean H is offline
Old 10-01-2009 | 07:52 AM
Sydwayz's Avatar
Forum Regulator
I have not seen that link above, but it appears to be pretty much all inclusive of everythng we would need. Member "warparty36" has made a lot of straps for members here and his company's straps appear to be of the same caliber.
You can cut off the extra length and use a blowtorch to melt the ends down a bit so they don't fray. Also, any upholsterer should be able to finish sew a new end once shortened.
I can't bring myself to shorten mine either, so I have used zip-ties to make the extra strap a fixed "unit" that slides on my pre-adjusted straps.
Sydwayz is offline
Old 10-01-2009 | 07:58 AM
Sea-Dated's Avatar
PM WARPARTY36. I think he can make custom tie downs for you.
Sea-Dated is offline
Old 10-01-2009 | 02:52 PM
25 hors la loi's Avatar
I like this one , don`know if you can have the wide you need ?
Hope this help
25 hors la loi is offline
Old 10-01-2009 | 03:01 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Just cut them to the length you want and re melt the frayed ends.
fireboatpilot is offline
Old 10-02-2009 | 12:06 AM
Strip Poker 388's Avatar
Rob
Talking
I use the M&R
http://mrproducts.com/
I have them on the car trailer and boat, we use them at work also.I liked the quality of the webbing/strap material better than the ones Ive seen out there.
The S hooks have a low rating.
Attached Thumbnails Tie Downs/ Straps-tabs%2520%2520trailer%2520012%2520%2528medium%2529.jpg   Tie Downs/ Straps-gf-d1058.gif   Tie Downs/ Straps-train-linol-1958-021-medium-.jpg
Tie Downs/ Straps-m-r-straps.jpg
Strip Poker 388 is offline
