Let's talk wheel spacers...
Spacers
The 1 1/2 inch spacers mean you can use them without grinding off the 1/4 inch of the factory studs for clearance. I have a 2004 2500 Avalanche and have a stock setup- no spacers. But I do have air bags on the rear axle. I honestly don't fell the back is tippy at all. I take corners just fine. When I get some time I may try a set of spacers.
Wannabe
Wannabe
If that's the case, I may just go with 1.5s to keep from having to trim.
Thx.
Yes, I cut the ends off with a grinder. If you don't want to do that, you could also get shorter studs installed.
