Myco steel (painted) trailer in salt? >
Old 11-19-2010, 10:31 AM
H20 Toie's Avatar
never had a problem with my myco steel using it in the salt but i also spent time cleaning it
but i see plenty of people that don't wash them down and they will not hold up
H20 Toie is offline
Old 11-19-2010, 08:23 PM
weldcrane's Avatar
if you want a steel trailer to last have it galvinized and color coated V&Sgalvinizing does all my stuff and there world wide
weldcrane is offline
Old 11-20-2010, 10:12 AM
BONDO10's Avatar
Sorry to hijack. Roughly how much is a new alum.Myco for a 38' to 40' v hull?
BONDO10 is offline
Old 11-20-2010, 08:15 PM
Expensive Date's Avatar
Depending on options I would guess 15k to 18k.
The reason I asked is about 1/2 of the boats at Shogren have steel trailers.I had flown out there back in August to look at a boat that had an Aluminum trailer but it was not really what I want.Need to wait a little while longer instead of buying something thats almost what I want.
Expensive Date is offline
Old 11-20-2010, 08:24 PM
http://www.teamshogren.com/pre-owned...lightning.html
Is it me or this trailer is to short for this boat,seems like it hangs off a little,its a nice boat though.
Scroll to the 7th picture.
Old 11-22-2010, 08:50 AM
Tom A.'s Avatar
Yes the trailer is too short but you may be able to move the bow stop up enough to make it fit right. The stagger in those engines really doesn't move the drives too much closer together or add any room! I guess they are a little closer mounted to the centerline?
Tom A. is offline
Old 11-22-2010, 09:19 AM
The 04 was only a semi stagger.I think 06 or 07 was a full stagger.
Old 11-26-2010, 10:33 PM
SS930's Avatar
Originally Posted by Sydwayz
I would never consider a steel trailer, even if I lived on a fresh water lake in the middle of the country. You've got 3 general areas of boaters:
-West Coast
-Midwest
-East Coast
If you have a steel trailer under your boat, you immediately give 2/3s of the buying market an excuse to chew your boat/trailer package price down come resale, as they "need" and aluminum trailer. If you are a midwest boater with an affection toward steel trailers, that's a "want" and not a "need". Hence, the value of an aluminum trailer under a boat sold as a package is a little stronger than steel.
I agree a 100%. I have not considered many boats because they came with a steel trailer.
Another factor is weight. Why tow an extra 1000 lbs if you dont need to???
As far as marine trailers go, steel shouldn't even be an option. A little common sense goes a long way... Then again, I still cant for the life of me understand why so many people buy hi-performance boats with Bravo drives either!!! I long for the day manufacturers start specing Arneson surface drives in there place as std equipment!
SS930 is offline
Old 11-27-2010, 12:04 PM
HUSTLEthis's Avatar
My steel myco is an 02 and is doing fine... I've towed my boat back and forth to Miami also... It's all about maintenance.
My question is why would you limit what boat you want to buy just because of the trailer? I think you're buying a boat. So it has a rusted trailer...sell it for 3-4k, add another 10k and get your new trailer.... If I'm buying a 150-200-250k boat, what's another 10k....Why limit yourself because of a trailer is my point.
HUSTLEthis is offline
Old 11-28-2010, 10:54 AM
SS930's Avatar
Agreed, but not everyone can or even wants to spend $250k on a boat, never mind another $10K on a trailer. If you're looking at a $50k or $60k boat, then having to spend another $10k on a trailer sudenly becomes much more significant.
SS930 is offline
