LB7 EGT's
I was driving more at people who post answers without really knowing what they are posting about on other sites that I've tried to get info from.
You know, the guy who always says "ive got a friend".... but he doesn't even own a truck...
If you notice I dont give my opinion on whats safe, I only explain what my experince is
I've got a friend or two that have duramax (lb7's) and they sled pull drag race and whatever else you could possible do to try and melt a piston and they never have. With these idiots melting pistions is not a problem but bending rods and putting a hole in the block is a different story. A couple of them don't even run any guages in there truck, not that i personally agree with that but, there logic is that even if they see that its hot while they are sled pulling or drag racing there not going to let off so they would rather not know where the egts are. When you drag race you egts are between 1600-2000 degrees for 12-13 seconds and if you sled pull it could be 20-25 seconds, so if you hit 1400-1500 degrees for 10 or so seconds pullinf your boat I don't think that its going to hurt anything. Don't try this at home:
http://www.youtube.com/user/05smoker#p/u/32/LHPyjSG9p2M
http://www.youtube.com/user/05smoker#p/u/33/hM-SNcrom_g
my 07 6.7 cummins pre DPF removal , pre EGR removal would easily hit 1400 + degrees mild acceleration empty , this is pre turbo temps, [crazy], now after gutting all that crap, now at cruise about 70 pulling the boat its approx 800 degrees.
IMO 1200 degrees for a longer period, 1300 for no more than 15-20 seconds tops.
