Originally Posted by Beak Boater
(Post 3340312)
5-7000 in my 7.3 F350. Not to hi jack, any advantage to running synthetic in a diesel?
Changing 14 quarts of oil on a diesel at anything less than 5000 miles is rediculous and wasteful and a waste of $$$. All of these engines are designed for 300k plus miles and 99.9% of the guys on this board can afford to replace their trucks WWWAAAAYYYYY before that. I used to change my Cummins are 5k and have switched to 7500 with Rotella. That engine will outlive my truck's frame and body by 10x. Synthetics can run from 15k to 20k with no drawbacks at all.
Diesel oil will be black after 500 miles so it always looks dirty, but by changing the oil too often and causing dry starts and having too many detergents built up in your engine you are doing a lot more harm than good |
Originally Posted by 575cat
(Post 3339813)
with the egr system on the newer diesels it will contaminate the oil severely .
Change mine every 5k miles oil and tires rotated. Ford 08 350 6.4 50K miles
I have 04 6.0 with 89k , i have had ford change it every
4.500 miles with ford oil, they say every 7000 Do you just change over to synthetics or is there different filter also , my truck is stock |
5K on all of my vehicles, including my PSD.
5K Rotella synthetic on a Duramax, people that are saying 25,000 miles "scare" me!
Steve |
Originally Posted by thanks_don
(Post 3340543)
Originally Posted by 509 SC
(Post 3340673)
Steve |
Have those who have gone the 15K miles done oil analysis?
| All times are GMT -5. The time now is 05:51 PM. |
