how are 2011 ford 6.7 dl holding up so far ???? >
Old 03-28-2011 | 04:52 AM
Just hit 110 miles on my 2011 F350 Lariat......so far so good... ..lol......I'll keep you guys posted when I rack up a few thousand miles.........I have to say one thing though, the interior is AWESOME!!!! The thing rides unbelievable and it really is quiet compared to any other diesel I have driven before.....so far, I LOVE it !!
Here's Johnny is offline
Old 03-28-2011 | 05:11 AM
Wow 110K on a 2011! And I thought I racked up some miles. Do you use it for work??
ElimiNordic is offline
Old 03-28-2011 | 06:10 AM
not 110k.......only 110 miles.....few days old......lol........
Old 03-28-2011 | 06:48 AM
Oh, Don't I feel stupid.
Old 03-28-2011 | 06:51 AM
BobbyB is offline
Old 03-28-2011 | 07:51 AM
Jassman's Avatar
Jeff,
How many miles before you fill the urea and how much does it cost?
Is the engine brake on the GM a lot better then the ford like the mags said?
oil changes between 6400-6900 miles depending on how much I tow...appr. 30.00 for the urea...but our fuel economy is up vs the Ford 6.0 and GMC 6.6....the Ford 6.4 were the worst, but ran great. Is it worth it....all I know in the winter time is I can start these trucks in the garage, and when I get down there is no smoke or smell..its better over the long run and in time even Dodge will be using it.
Jassman is offline
Old 03-28-2011 | 08:56 AM
Jeff,
Ours needed DEF right around 5,000 miles and it was not very expensive at all from a local NAPA.
The GM has a switch in the cab. I had to lease a 2011 Duramax and it seemed to work a little better. But both systems are not like a Jake Brake or Exhaust Brake with a Valve. They work off turbo back pressure of the high RPMs from the transmission down shifting I am being told.
I went into this truck thinking I would have exhaust braking every time in tow/haul mode. This is NOT AT ALL THE CASE! In 6th gear on two lane roads while towing I watch my speed increase 10-15 mph if I don't do anything. I submitted this to Ford and their reply was I needed to be in Tow/Haul mode and the RPM has to be above 2000. The problem is this, in 6th gear I am at 1300rpm and 5th I am at 1700rpms.... nowhere near 2000! Once in 4th or 3rd I am well into the 2000RPM range, but all I am feeling at this point is transmission/gear braking an no engine/exhaust braking. The increased back pressure is a by-product of the higher RPMs.
I would not let this keep one from getting this truck. If you are really wanting an exhaust brake test drive all the trucks.
TW720HVY is offline
Old 03-28-2011 | 09:57 AM
$ 13.00 a gallon down here BIG Daddy
Old 03-28-2011 | 10:26 AM
where r u, bill. fla still?
Old 03-28-2011 | 10:56 AM
Too Stroked's Avatar
[QUOTE=mrfixxall;3360603]he also said that the engine is 3/4's of the way under the cab and good luck trying to service it,he also said that if the serpentine belt were ever to go its not something you will be able to do with out taking the fan shroud off to access the belt..[QUOTE]
True, but remember, Ford has made it very easy to remove the cab from these trucks to address that very issue. Once the cab is off, everything is pretty easy to get to.
Too Stroked is offline
