New electric brakes
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
Ok, after going out and looking at several of the sites above, are all electric brake setups drum? I currently have surge disc brakes and really don't want to step back to drum. With three axles to redo, changing everything is going to get pricey, especially if changing the rotors. As you can tell, I don't know alot about trailer brakes.
I plan to unplug right before it goes into the water but am looking forward to having brakes while backing down a steep ramp.
Are the brake solenoids made for water immersion? I always thought that the reason surge brakes were used on boat trailers is because the electric solenoids were not meant to be totally submerged. I too need to rebuild my trailer brakes, and electric would be MUCH better than surge (and cheaper than EOH). Any info is appreciated.
I am looking at Dexter, they have some Nev-R-Adjust Electric Brakes:
•Eliminate brake adjustments. Brakes automatically adjust to deliver optimum performance and braking power
•Reduce stopping distances 50 percent more than other brakes
I have used those on 2 trailers, I am very happy with them.
I have a 37ft trailer built by Load Master out of Ohio (2 yrs old). I have electric brakes on all 3 axles. Not 100% sure, but i think they are drum. They work great. I do NOT unplug my electrical connector. Loadmaster told me the solenod is sealed. Not sure of brand they put on. I do have to adjust the truck control to zero gain when unloaded or the brakes lock up with the slightest touch on the brake pedal. I love having brakes when backing down a steep slick ramp. Hope that helps.
Thanks guys, looks like going EOH is probably my best bet. With replacing all the rotors, the price of pure electric will be just as much if not slightly more than EOH. Just rebuilding my surge system is probably the cheapest, but I HATE that constant thumping of the actuator.
with electric over hyd. you can weld the coupler solid . that is where the electric part come in , it has a electric pump to build hyd presure to aply the brakes when you hit the pedle . also the disc brakes are the best period ...
