Best Electric over Hydraulic Brake Acutator
1 Attachment(s)
My Ausco electric over hydraulic brake controller from a 2001 Extreme trailer is done. It is a triple axle trailer with disc brakes on all three axles. 34 foot cat with about 12K pounds weight.
In my set up, I need to back the trailer to the point where the brake acutator is covered with water most all the time during launching. I tow with a 2011 Ford PSD with integrated controller which supposedly has some kind of antilock system and a separate setting for electric over hydraulic brakes. I looked on etrailer and basically can get the titan, carlisle, or dexter systems. Anyone got a recommendation as to the best acutator with the integrated controllers. Thanks, Eric |
Just bought new trailer with Titan Brake-rite. Dealer had no ideal how to set up proper installation for my chevy integrated controlor. Called brake rite and i wired actuator correctly with a couple of brake magnets tied in to trick the integrated controller into thinking a trailer is attached and everything works flawLess. It will flat lock up a triple axle with no problems. Very seamless operation with my chevy.
You need to mount the actuator above the water line. It's electronic. |
i have the brake rite as well and only having a dual axle trailer with a 272 baja i could almost not even use my truck brakes and the trailer brakes work that good
Thanks for the replies. I will mount above the water line if I have to... The Carlisle unit say rated for marine/submersion.
Quote:
Dexter or Carlisle are the best. |
I have a 2006 Load Rite trailer with a Carlisle actuator and just found out it is toast with less then 500 miles of use. I think the shop is replacing it with a Titan. Carlisle offered no way to repair or refurbish the unit, just $900 to replace the whole thing.
I made a lot of phone calls yesterday. From what I found out none of them are water proof due to the need for a vent, so I must mount it higher out of submersion. No problem.
As far as compatibility, there is diffenence drum vs. disk. have models for each. Dexter, Brakerite, Carlisle have models compatible with the Ford Controller. There are some problems with the new GM controllers and the acutators. If your buying one make sure you get a new serial number to get the new compatibility changes. I think the brakerite and the dexter were recommended highly but I went with the dexter because it had a more water tight case and all solid state electronics. But all praised the Brakerite. Didn't hear anything bad about the Carlisle except from driverkr above. One of the people I talked to said the best way to kill them is to overheat them by keeping your foot on the brake for a long time. Say your waiting at a long light or for a train, etc..... use emergency brake. Thanks for the replies. Got from Eastern Marine, they were very helpful.. Eric |
Quote:
Quote:
Wrinke, It seem like the manufacturers now have adapted to use OEM controllers. Except the new GM piece.
| All times are GMT -5. The time now is 01:32 AM. |
