Nor-Tech 50' cat behind a 3500 GMC?
Just a question. I live in copenhagen, so we are pretty much in the same boat. What do you mean by new trucks not being leagal? Also, norway is not part of the EU, so why can't you buy engines, that are out of the EU emmision laws? Are airbags leagal in Norway? They aren't in Denmark. I would get a flat bed truck with a crane, and load trailer, boat et al, up on that, and have them deal with the permits. Plenty of companies up here that hauls boats. Besides. When you have the money for that boat, why on earth not spend a little on safe transport? The Norwegian police is not exactly easy going either, when you're doing traffic violations.
Sorry for the off topic.
Thanks for the input everybody!
You are right. This country is something of its own.. We are not part of EU, but we do follow all the EU laws. I guess it is a matter of importing all kinds of fereign citicens etc that the Norwegian gov don't want. We are allowed to use air bags (on the leaf springs). I need to get the boat up and down from the ramp, and get it where it should be all the time. Can't order truckers for that! I guess this is a pretty rare problem anyway. I just want to know what you guys mean, who have more experience with these systems.
Who cares about the length, trailer type, brake type or year of truck..
HOW MUCH DOES THE BOAT AND TRAILER WEIGH TOGETHER?
Thats where you're going to get stuck.
Will it stop properly? Yes. If you have the right brakes under your truck and trailer.
Will it pull it? Yes.. Theres enough HP assuming you're running a diesel.
Will it wander all over the highway because the front of the truck is in the air? YES.
If you had a trailer brake failure, would the truck stop the entire weight of the rig? NO.
Im assuming a 4 engine 50' cat is going to be over 20k. Adding leaf springs, airbags and all that will help significantly with stability but you're still taking a chance. You've got a LOT to lose, literally, behind that truck.
You sure you want to save a few bucks and risk it? You should really consider a truck upgrade...
I may be wrong, the weight may well be within the capacity of the truck. But I doubt it.
You are right. This country is something of its own.. We are not part of EU, but we do follow all the EU laws. I guess it is a matter of importing all kinds of foreign citizens etc that the Norwegian gov don't want. We are allowed to use air bags (on the leaf springs). I need to get the boat up and down from the ramp, and get it where it should be all the time. Can't order truckers for that! I guess this is a pretty rare problem anyway. I just want to know what you guys mean, who have more experience with these systems.
But you're going to wear that truck out very soon towing that much weight. You would do well to find a Class 6 or 7 truck that is built to handle 20,000+ lbs.
Do you own a boat storage business and have a ramp for your customers or is it just that one guy with the humongous boat? You took the helper spring off so you will need to either reinstall it or go with air bags. I recommend bags which will ensure level towing.
^^^Looks like you've got it figured out then. I take it your truck is a diesel? If you don't have an exhaust brake on it, that would be the best addition you could put on your truck.
http://www.thoroughbreddiesel.com/bd...-brake-kit.htm
http://www.bankspower.com/magazines/...-Exhaust-Brake
