Which year was the best Ford F250 Diesel Engine?
#52
True. No doubt about it. The new 6.7's are indeed incredible pieces of technology running 400hp and 800 ft-lbs of torque, but along with all that come other complications and a whole new plethora of associated failure points. The engines themselves are strong, but I'm hearing a lot about NOX sensor failures, DEF faults, HPFP failures from hyper-sensitivity to wet fuel, etc. If one were to simply asked which Ford diesel was/is the best...simply put, I think that most folks would agree that the most dependable, most reliable, most bulletproof engine was indeed the old 7.3s. The comfortable average lifespan was easily 300K+ miles without any worry.
#53
#54
3/4 of the time I let the dealer install everytime while getting an oil change..its the same cost as I can get at the truck stops..they just pour it in.. On the Fords its right next to the gas cap..on my GMC its under the hood..a little more of a pita. The 12 Cummins HO it is not required, but that will change for 13... Just turned 109k today on the 11 F250...running strong.
