-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Hitch Rattles (https://www.offshoreonly.com/forums/trucks-trailers-transportation/278498-hitch-rattles.html)
weldcrane 06-13-2012 08:16 PM
run a couple beads parrallel with th hitch on the hitch grind to fit then grease the hitch up rattle be gone
Plowtownmissile 06-19-2012 07:39 PM
Originally Posted by US1 Fountain (Post 3707857)
Run a small bead of weld along hitch, then file/grind to fit.
I had the same problem and almost did the weld a bead and file down job. Thankfully, I found a better and much easier answer...
Pull the hitch out of the receiver. Run two wraps of electrical tape around the hitch (one wrap on both sides of the pin as far to the ends of the reciever as possible). It will take about 10 minutes to do it even with checking the fitment and it can be undone easily. It works like a charm!
Splitlanes 11-05-2025 12:34 PM
mine rattles
pullmytrigger 11-07-2025 07:16 PM
I put one of these on....rattles GONE!
Griff 11-07-2025 08:58 PM
I've been using this one for about 5 years. No rattles or clanking, even with surge brakes.
phughes69 11-10-2025 07:52 AM
I had the same thing as what Griff and pullmytrigger , used except the hitch on my truck is a 2 1/2" class V When I use my camper trailer the weight distribution hitch is 2" so I have to use a adapter sleeve. With the sleeve the play is horrendous and the trailer bounces all over the place because the weight distribution bars are putting leverage on the hitch to pull it up. I had one of those anti rattle hitch tighteners but when I would tighten up the U bolt, it would bend and eventually broke. I had two of the big bars and ended up using two 5/8 bolts to tie the big bars together.
Bondo 11-11-2025 07:03 AM
Ayuh,..... If I can hear the hitch rattle,.......
I turn the radio up louder,...... :cool:
