Ford 6.0guys, feedback
Thanks guys I am not a gear head and was definitely looking for this kinda feedback, its a decent deal and the truck is mint, but I think I will walk, Ive been doing homework on the next move at the end of the day I think i will be buying a gasser and spend a little extra at every fill up to avoid these monster issues, Duramax seems to have a better track record, however if you encounter a injecter issue $$$$$$$ cha ching, Damned if you do and damned if you don't
The advancements in gas engines in the past 4 years, along with 6/7/8 speed trannies give you many options over a diesel. Not to mention by 2014 the new emissions standards will have all the new diesels getting 10 mpg.
I still have my 06 6.0, other than a couple injectors the engine has had no major problems and truck has 240,000 mi on it today and still pulls trailers up to 15,000 lbs. There was some kind of oil valve in the valley or something that went bad (maybe EGR) at like 85K and it's been fine since.
We change the oil every 15,000 - 18,000 mi. Had thousands of class 8 trucks over the years and do not believe in the short interval oil changes, let it stay in longer and do it's job. Everyone else says that is a sure fire way to ruin the engine and cut down life, never saw it in any of the Navistars we've run or our Cummins product.
I would go for it. My words of advice is coolant filter kit, egr delete, oil cooler upgrade, exhaust and a good tuning and it will be just as reliable as a 7.3. The only reason 6.0ls fail all comes down to the coolant. A combination between silica contamination that plugs the oil cooler passages and destroys injector seals with the added oil temp, and the coolant acid levels created by the 800*+ temp change in the short distance between the inlet and outlet of the egr cooler. If the egr cooler is on the motor, rule of thumb is the oil temp should never exceed +30* to the coolant temp. The 6.0l is a great motor with the propper PM and modifications. The key is to fix it before it breaks because of the snowball effect. Just my $.02
I love mine!!!! Great power to pull the boat and the TorqShift trans works flawlessly. They did have some issues, but that is all you ever hear about. Look at how many are on the road and have had NO problems.
Buy a 99 to 03 with the 7.3 Unbelievable motor. Keep the oil changed properly and they're almost indistructable. Thery're are plenty of low mileage 7.3's around for sale. My son has 235,000 on his and it runs like the day it drove off the showroom floor. Had 270,000 on mine when I sold it. No issues. Have never had to lift a wrench to either one. They will run 300k to 400k with no issues and give you 18 mpg. It's a no brainer. 6.0's, 6.4's and know the 6.7's that need a tank of piss to run!!!!! Duramax??? All POS IMOP.
I have a 6.0. It rocks. They need monitoring. Read this article and make your own conclusion. http://www.powerstroke.org/forum/6-0...ning-6-0l.html I am in cheektowaga and have an edge insight and could look at it with ya.
Here is the deal with the 6.0. Any good tuner (person writing your tunes) is not going to give you a tune that is going to tear up your truck. There are trucks all over the place running 400-420 rwhp with 750-800 rwtq all day long without problems.
Yes the 6.0 is known to blow head gaskets. This is why it happens. The Ford Gold coolant contains silicates. The silicates are not able to handle high EGT's generated by a good load or relatively high boost when they run through the EGR cooler. They break down into a gell like sludge and fall out of suspension. This crud gets caught up in the tiny coolant passageways of the oil cooler. As the cooler clogs up it restricts coolant flow to the egr cooler. Now the egr cooler doesn't have enough coolant to carry off the heat generated by high EGT's. The limited amount of coolant in the egr cooler flash boils causing high pressure in the cooling system and the truck pukes coolant from the degass bottle due to the pressure. (it has to go somewhere)
Your uninformed Powerstroke owner is not monitoring his coolant temps and oil temps so he doesn't know whats going on and he keeps driving it this way. The problem gets worse, the pressure causes the egr cooler to rupture. Now the egr cooler is leaking coolant into the intake manifold which then runs into the cylinders. Again the high combustion temps cause the coolant to vaporize. This causes unacceptably high cylinder pressure, the TTY head bolts stretch due to the add'l pressure and there go your head gaskets.
Ok now you know the problem. Here's the cure. Get a good engine monitoring solution like the Edge Insight so that you can monitor your ECT and EOT. If those temps get more than 15* apart with normal cruising when at normal operating temperature your oil cooler is clogging up. Rebuild it now to prevent all that down stream damage from occurring. Flush that Ford Gold coolant crap out of your engine with a couple bottles of Restore. This is made specifically to clean out that silicate residue. Now refill it with a silicate free Cat EC-1 rated ELC coolant. This removes the silicates that clog the oil cooler from the equation. If you live in an area where you don't have smog inspections delete the egr system. If you can't delete it replace the egr cooler with the cooler manufactured by Bulletproof Diesel. This is vastly superior to the Ford oem egr cooler and it will not fail on you. If you find that you need to replace head gaskets replace the TTY head bolts with ARP studs and use OEM Ford head gaskets, the black onyx (Victor Reinz) head gaskets have proven to have a high failure rate. If you have to replace the egr cooler always replace the oil cooler. That is the source of the problem.
Now that you have addressed the common problems that scare the he11 out of people, get an SCT tuner (i like the X3) and install some custom tunes and drive the heck out of it. DO NOT baby it. The Powerstroke hates this and will rebel with turbo issues.
Turbo issues are also common repair points with the 6.0. People like to complain that it's because the VGT turbos are pieces of junk. This is not so. The VGT vanes in the turbo need to be exercised regularly. This means making them go through their full range of motion. So put your foot in it regularly and let it see some full boost runs. That will keep your VGT vanes from getting all sooted up and freezing up because of the soot. Again, that is what happens when you baby it. Put your foot in it and you will have less problems. Lay out of it and try to milk it for mileage like you would a gasser and you're going to have turbo issues. Don't let it sit either. That is also the kiss of death to the turbo. The unison ring rusts up and again you have turbo problems. So now that you know you need to give your turbo a regular work out to keep it happy, give it a proper cool down as well. Just whipping into your parking place and shutting it down will lead to coking the bearings and again major turbo issues. Running a good synthetic oil will help here immensely because it handles heat so much better and resists coking. But always let your turbo have time to cool down. This is one of the reasons you need a Pyrometer (EGT gauge). Let the EGT come down to 350* before shutting your truck off. This only takes a couple of minutes, especially if you take it easy on it for the last couple minutes of your trip. If this is too much hassle for you get a turbo timer that will automatically delay shutdown when you turn off the key to allow the turbo to cool down.
Injectors. Ford's HEUI injection system fires the injectors with High Pressure Oil, to the tune of 4,000psi at Wide Open Throttle. Maintenance is critical here so you can not let your oil maintenance slide like you can on a gasser. It will kill your injectors. The injectors also are known to suffer from something that we call stiction. That is when the oil side plunger of the injector hangs up or sticks when cold until the truck warms up. I believe this is caused by varnish buildup that is common to dino oils, especially those containing paraffin. Using a good synthetic oil will take care of that because it actually cleans the engine as it lubricates. If you do find yourself with some injector stiction add a couple of bottles of Rev-X to your oil. It has cleared up 99.9% of the trucks it has been used on. 2 bottles run around $70. A new injector is about $250-$290. Be anal about keeping your oil clean and fresh and changing your fuel filters regularly. The other thing that kills injectors is low fuel pressure. The fuel pressure needs to stay above 45psi at all times and is typically set around 52 psi from the factory. Well the factory fuel pressure regulator spring is weak and looses it's tension over time and can't maintain adequate fuel pressure. There is an updated rebuild kit that uses a better, stronger spring. Installing this spring will bring your fuel pressure up to about 62 psi and solve that. Get a fuel pressure gauge. It's important.
So that covers the frequent complaints with the 6.0. They are all well known at this point as are the solutions. Does it suck we have to fix Ford's blunders? Heck yes it does. But again we know how and once done you will have a very reliable robust truck that is well worth the effort. So address the issues as you can and enjoy your truck. It is a dynamite vehicle. I love mine.
