What size truck will be needed?
Old 04-10-2013 | 06:58 PM
Originally Posted by 88242LS
this is a very stout package, I'd like in a GMC badge, of the boats mentioned you will be forced into a 3/4 ton except for the 292 Formula, it can be done with a properly setup pickup, I tow my 303 Formula with a 05 Sierra 5.3, plenty of power, not enough tranny, 09-to current with a 6 speed and 373's rear end is the ticket, and it also depends on how far your towing, 85% of my towing is within 5 miles,
Formula is first on my list but last on hers.
Towing will be short unless I do the key west run. But that will be a one time once only trip.
Nate5.0 is offline
Old 04-10-2013 | 09:18 PM
Originally Posted by Chart
In your shoes, I'd go reconsider the older dedicated pulling truck. With the cost savings, buy a car you'd feel comfy driving all the time. Yes 4 vehicles is a pain, but sometimes the right thing to do.
I agree.
If 40K is your budget, find a nice 2500 or 3500 with a big gas engine for around 10-15K (or less), and pick up a car or 1500 to DD with the rest. That way, you can keep the Tow Rig hooked up and ready to go, all of the time.
Bowtiepower00 is offline
Old 04-10-2013 | 10:53 PM
2500 3/4 Ton and you will LOVE IT. Especially if diesel and you modify it a little they are a blast to drive.
offshorexcursion is offline
Old 04-11-2013 | 04:56 AM
I have the firestone air bags on my F-250 to handle the squat. Mandatory on them in my opinion. Cheap and work great. Mine is a daily driver and is very comfortable to live with. Actually is the daily driver of a lot of Docs here...
SkiDoc is offline
Old 04-11-2013 | 07:44 AM
x2- I installed the Firestone Air Bags on my 2500 Avalanche - with leaf sproings and what a difference! Smoothed out the ride for the truck and boat. I recommend this highly!!!
Wannabe
wannabe is offline
Old 04-11-2013 | 08:24 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Some size attributes:
The Fords "feel" bigger because they have a larger interior space. Shoulder room is wider; especially over a GM.
The Ford and Dodge center consoles are wider than a GM so they push the passengers farther apart which also adds to the size difference effect.
The Dodges are a little different feeling because the windshield stands at a steeper angle than the other two manufacturers, making the windshield shorter, but still just as tall. This changes your perception of interior size.
Also, the interior bed depth of a Dodge is a bit shorter than the other two. I have tool boxes that fit under a tonneau cover in my Ford, that don't fit the same in a Dodge.
Any of the modern trucks which have coil spring front suspensions (tight turning radius) are fine for city driving if you know what you are doing; especially with a rear view camera which is stock on the higher end models, and easy to add if not.
I've had airbags on my last 4 full-size trucks/SUVs. I do not tow without them.
Sydwayz is offline
Old 04-11-2013 | 09:14 AM
those boats are probably more than any half ton can take specially a chevy. If anything maybe an ecoboost but those tow 11,300. Personally a 3/4 ton will be fine, id go diesel.
soldier4402 is offline
Old 04-11-2013 | 09:54 AM
I did a few quick searches and found a 2007 GMC 2500 diesel 4x4 that's loaded with 60k on the dash for $30k.
Like that idea.
Might even hold off for a few months....buy the boat...high and dry for a few months while I figure out exactly what it is that will fit my needs best.
Nate5.0 is offline
Old 04-11-2013 | 10:02 AM
Like that idea.
better deals than that out there. In 2009 I bought a 2007 Ford power stroke FX4 with 30k miles for 27, then in 2010 bought a 2008 Ford 6.4 diesel XLT with 14k miles for 30k. Id look harder.
Old 04-11-2013 | 10:52 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
True, but Ford's are different. They have had complete evolution changes of their engines several times since 1999. Dodge has only had 1. GM has only had 1. The several evolutions of Ford's has put a lot of used ones on the diesels on the streets as folks move to the "better" diesel offering by Ford.
And, diesel price fluctuations as well as more powerfully rated gas engines have affected diesel truck prices over the past 4 years or so quite a bit; more than any other time I can remember.
Sydwayz is offline
