Replacing Trailer Bunks
Old 09-06-2013 | 10:31 PM
I ended up calling Eagle. They said they use Grade A pine, untreated, and so I did too. I gave it two coats of Thompson's Water Seal, spent a few few minutes with a pneumatic stapler and I'm in business!
glboatdriver is offline
Old 09-07-2013 | 08:02 PM
Default Bunks
I did mine WAY different. I did not wrap the bunk. Wrapping retains the water and rots the board. I used DF from Home Depot. I routered all the top edges to a half inch radius, I then glued indoor outdoor on the top flat that contacts the hull. Used liquid nails.. 6 years now and still looks the same.
fossil fuel is offline
Old 09-09-2013 | 12:34 PM
Pics and material list?
ALL_IN! is offline
Old 09-12-2013 | 07:41 AM
+1 Just did mine too. Local trailer builder confirmed untreated wood...said treated wood has chemicals that in his experience eats up the carpet in just a year or two. I was also told expect 8-10 years on the boards, at the most and I'll be at it again. We shall see, right?
motocop is offline
Old 09-12-2013 | 09:56 AM
Several bunks on my 2002 Eagle are in need of replacing.
What wood are folks using? Treated or untreated. Cypress or cedar or pine? Or is there another material (PVC, for example) that I should consider?
Thanks.
If you plan on keeping the boat for a long time use Trex. Will last forever.
dewayne6243 is offline
Old 09-12-2013 | 10:09 AM
I was thinking dont they sell the boards int he composite decking material, if they are the same size, those would last forever you would think.
soldier4402 is offline
Old 09-12-2013 | 10:42 AM
I know they make 2x6.
Old 09-12-2013 | 11:06 AM
I know that, I thought I have seen 2x4 as well. Im sure you can find them online. Triple the price but no rot and no replacing again
Old 09-12-2013 | 12:16 PM
VoodooRob's Avatar
Stapling into Trex and getting the staples to hold might be an issue. Don't know never tried.
VoodooRob is offline
Old 09-12-2013 | 01:19 PM
Glue it down with fiberglas resin.
