$15k to spend on a truck help
Old 11-15-2013 | 03:16 PM
  #61
Originally Posted by Griff
Keep looking for an 8.1/allison. They are kind of hard to find. Use the 8100 and 8.1 as search keywords on autotrader. The 8.1's were in 2001 through 2007 Classic's and were DC'd after that. I had to drive about 5hrs get my current one.
BTW, My 32 AT on a steel trailer wieighs over 10k and probably closer to 11.5k full of fuel.
I have found several nice Avalanche with the 8.1 but how do i knowif it has the Allison Transmission? Seem to be quite a few more Avalanche on the market with 8.1's than just he standard Chevy/GMC 2500 wonder why that is?
bigredbaja is offline
Old 11-15-2013 | 03:34 PM
  #62
Avalanche 8.1 will have a 4L80E...still a good trans
boatnt is offline
Old 11-15-2013 | 03:40 PM
  #63
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by drejustice
I might be convinced to sell my 2006 Chevy 2500 Avalanche with 4:10 gears and 98K miles......as i'm trying to talk myself into a 2014 Ram 2500 Mega cab even though the Avalanche pulls my boat fine and I think would handle whatever I may wanna get in the future.
I'll give you $1500 AND I'll toss in my Dodge Ram 2500 for FREE. See you tomorrow. Have it washed.
Sydwayz is offline
Old 11-15-2013 | 03:54 PM
  #64
One i found the service manager said 4L85E what does that mean any idea?
Old 11-15-2013 | 05:03 PM
  #65
Originally Posted by halfgassed
Mild Thunder, I've gathered you like the vortec 454's. Are they pretty responsive? I tested out a 94 tbi 454 dually the other day and it was a pooch. The last tbi 454 Ihad had a stick behind it and it was ok, but the auto made it seem poochy. I've never had nor drivin a vortec 454.
I've been thinking about building my next tow rig out of a early 80's crew cab dually and I'm trying to figure drivetrain. But if I can avoid and engine/trans swap and straight axle a vortec truck like I did a previous tow rig I had....I'd be pretty happy.
nothing wrong with the tbi's ..you just have to know what to do with them,,for one they retard the crap out of the timing..everyone i have worked on was 2* retarded.timing..next order a piggy back chip that plugs into your pcm,,next,,get a adjustable fuel pressure regulator and crank up the fuel pressure to 16 psi @ wot..gm has them set at 13 psi and they lean out when you stick it to the floor,next install a msd 6al2 box..mine rips still and it has 470,00 k on it...i get 10 around town and 14 pulling my 4 place enclosed low profile trailer on the hyw,,but i have to keep it unser 70..its a suburbas with 3.73 posi and 285/75/16 tires..ps i put the timing @ 4*..
FIXX is offline
Old 11-15-2013 | 05:31 PM
  #66
clean 2500 HD 6.0 w/ under 100k miles for 8-12k. If the tranny bothers you... you can rebuild a 4l80e for 1500 bucks if you r/r yourself not to mention it is a very good tranny anyway
sparky24 is offline
Old 11-15-2013 | 05:37 PM
  #67
i really feel that the front of the frames on gmt400 trucks is too weak for a solid axle (over time it will crack), i would rather start with a clean k30 frame
sparky24 is offline
Old 11-15-2013 | 11:40 PM
  #68
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
4L85E is AKA the M32. Not a big deal. ALL of the 2500 Suburbans and Avalanches came with this transmission when mated with the 8.1L.
It's a 4-speed with Overdrive.
It's not the Allison 5 speed automatic, but it does fine.
I had a 2500 Avalanche back in the day, and posted a bunch of info here on OSO in the past.
The 4 Speed Automatic can't handle the torque the way the Allison can, so on the 2500 AV/Suburban it is electronically limited to reduce the torque by 30% until you get out of first gear (from a dead stop). You can use an aftermarket tuner (I like the Diablo Sport Predator) to get that torque back, but you do have to go easy on the go pedal. The 8.1L has a LOT of torque, and with a few mods it makes even more.
For the above reason, IF you can find a 8.1L in the 2500 Truck platform, it will have the Allison 5 speed auto, or the ZF 6 speed manual--AND you will have a bit better setup, but there is nothing wrong with the 4L85E in the Avalanche/Suburban 2500.
Sydwayz is offline
Old 11-16-2013 | 12:25 AM
  #69
The vortec version is better than the tbi. They are 9:1 vs the tbi 7.9:1, roller camshaft, better heads, port injection runs much smoother and cleaner,obd ii pcm, the engine doesn't run out of steam at 3500rpm. Stock they have torque management like the 8.1 . I had mine tuned and torque management removed. With the tune it is quite a bit peppier.
Stock injectors are known to leak along with the fuel psi regulator. Replaced my stock injectors with LS6 injectors out of a 02 vette. Needs to be tuned for these since they are larger. But stock ls1 injectors from a 98-00 ls1 can work without a tune.
I forget the specifics of the 4l80E but sometime in the 96-98 timeframe, they made some internal improvements. My dually has the 14 bolt GM rear axle.
As for the solid axle swap, I have no input. I am fine with the stock torsion bar independent front suspension. I only use 4x4 at the ramp. I actually think the truck rides pretty decent for 4x4 dually .
MILD THUNDER is offline
Old 11-16-2013 | 06:37 AM
  #70
Yes that transmission is fine. It is the same family as the 4L80 , The 4L80 and 85 are based off the old GMT 400 which was a bulletproof tranny from the 60's and added an Overdrive gear and lockup. I have 135k on mine with no major issues.
You should get 11-12 mpg in town and 8-9 towing. If you get the Avalanche 8.1 I would tune it with a Hypertech tuner- it did wonders for mine- added another 500 rpm usuable range. Also gave me about 0.5 mpg
Wannabe
Attached Thumbnails k to spend on a truck help-cat-avalanche.jpg   k to spend on a truck help-cat-avalanche.jpg
wannabe is offline
