7.3 ts 6 pos chip
Old 05-06-2014 | 06:13 PM
Default 7.3 ts 6 pos chip
Anyone using the chip mentioned above? I have been looking and talking to guys about this. I may be interested in getting one with custom tunes from PHP. Thoughts? Anyone have one for sale
drpete3 is offline
Old 05-06-2014 | 08:50 PM
I use the ts chip tuned by tony wildman. Works great flip on the go and haven't had any glitches with it at all since had it. Even had some different tunes burned into it while we dyno tuned it... Truck is 1999 7.3 auto with a lot of upgrades internal and external motor wise and fully built trans...
JPD Motorsports is offline
Old 05-06-2014 | 09:51 PM
Ts, tony or Jody Tipton all good sources for 7.3 tuning. The super chips flashpaq is actually pretty good for mild tow/mileage
Unlimited jd is offline
Old 05-06-2014 | 10:10 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have a Bully Dog 6 position chip and have been happy with it.
Sydwayz is offline
Old 05-07-2014 | 05:36 AM
I'm not sure what gears my truck has. How can I find out?
drpete3 is offline
Old 05-07-2014 | 05:41 AM
I have read that tunes by Jody and tony are very good as well as php. Not sure I'll be happy I spent 3-400 when I pretty much just tow the boat with the truck
drpete3 is offline
Old 05-08-2014 | 01:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There should be a metal tag hanging on one of the rear axle gear cover bolts. It will tell you.
Of that vintage, most of the SRW trucks came with 3.73 and DRW came with 4.10.
Sydwayz is offline
Old 05-08-2014 | 02:34 PM
If you want to go cheap just do a single tune flashed to the computer.
Aqua Banshee is offline
Old 05-08-2014 | 03:38 PM
like a 40 hp tow? Will that decrease my milage if do just some normal driving?
drpete3 is offline
Old 05-08-2014 | 04:11 PM
How often do you tow with it and distance.. Do you use truck in winter and need to warm it up?
If you strictly tow with it and don't use for other reasons a single tow tune in the range of 40-50 would be ok. The tunes usually hold the trans between gears longer locks up converter longer and a little firmer shift. Great for towing, everyday driving it gets old kinda quick.. If you did a flip chip, could do a 1stock, 2high idle, 3economy, 4light tow, 5heavy tow, 6valet or a security no start.. Another simple out of box unit would be a bullydog gt tuner, can usually find em cheap, and they will monitor as well...
