Trailer tire load range question >
Old 10-14-2014 | 12:00 AM
Default Trailer tire load range question
My trailer tires are dry rotted and need replaced. I have 14" wheels on my trailer. My boat is a 1996 Baja 236 and sits on a tandem axle trailer. I would prefer not to go with trailer tires again because they do not seem to last as long.
My question is will a tire with the load range SL be sufficient? Max load on the tires is around 2000. I think my boat weights around 4000 pounds plus the trailer.
I did look on here first to find my answer and it seems everyone is using E range tires. I'm having and issue because my 14" rims.
Thanks.
eib8400 is offline
Old 10-14-2014 | 06:06 AM
Sydwayz's Avatar
Forum Regulator
Upgrade to 15" wheels of you can. You will have a lot more options.
Second, look into Maxxis brand tires. They are all I would run in those 14 or 15 inch size ranges. They make some great tires.
Sydwayz is offline
Old 10-14-2014 | 06:47 AM
Ditto. I have these on my trailer in 14" and they are awesome. Discount tire carries them.
Dave
08 fastech 292 is offline
Old 10-14-2014 | 08:36 AM
Ditch the 14's and get into some 15's. Get any LT tire. Try Tire Rack. Best pricing I have found.
gofastboater is offline
Old 10-16-2014 | 09:01 PM
Thank you
eib8400 is offline
Old 10-20-2014 | 10:34 AM
I switched from 14's to 15's and got the Maxxis M8008 trailer tire and could not be happier.
This is a very good deal with no tax or shipping. http://www.ebay.com/itm/4-NEW-205-75...30ffeb&vxp=mtr
I bought these rims http://recstuff.com/15X6-5-4.5-White...ler-Wheel.aspx
And had a friend who works at a Toyota dealership take them in and have his tire guy mount and balance them for $40.
JWay is offline
Old 10-23-2014 | 09:49 AM
eib8400, you'll most likely need a "tall equalizer" for the springs to help with the 15" wheel/tire clearance. Not expensive but you'll probably need an impact wrench to get the old ones off.
Did this on my old trailer to get ride of the 14"s and get E rated tires, next to the EoH brake system it was the best thing I ever did to it.
TW720HVY is offline
Old 10-28-2014 | 11:09 PM
I will have to check into the "tall equalizer". Never heard of it.
eib8400 is offline
Old 10-29-2014 | 08:29 AM
They look like this....
http://www.rvplus.com/trp-corporate-...1MQhoC6A3w_wcB
As compared to this equalizer...
http://www.rvplus.com/trp-corporate-...-2-eq-104.html
Keep in mind that not all trailers are the same, what worked for my Heritage Trailer my not exactly work for yours. If you have a Heritage you can call the factory for the part, that's where mine came from. Here is their link...
http://www.heritagetrailers.com/
Good luck and hope this helps.
TW720HVY is offline
