Opinions on 6.4 Ford deisels.....
Got a Duramax for sale 2006 crew, 4x4 LB . http://charlotte.craigslist.org/cto/4936204906.html
I agree. I know a handful of guys locally that have them. All over 200k with no issues. One buddy has 440k on his untouched. Just now is doing injectors, ball joints and shocks. All of them around here are LBZs fwiw. As a person that is not brand loyal at all, (7.3 and 6.0 owner) I would own a duramax if i could afford one. They just take a beating.
The 6.0s and 6.4s are good motors as long as you take care of them and address the weak spots. I really think a lot of the 6.0s bad rap came from people wanting to maintain them like a 7.3. The newer diesels are much more finicky about clean oil and fuel. I have a bulletproofed 6.0 and love it and wouldn't hesitate on a 6.4. The 6.7 is nice but the new def systems are a pain in the ass and are not good for the motors. If I was going to replace my 04 dually it would be with an 08 to 10 6.4 f-450. That is the most complete towing package going. The 2015 450 has the good axles again but if I were to buy a 6.7 the def system would have to go. I'm prolly a lil different than most buyers as I do all my own work. I can have the cab off a 6.0 truck in 2.5 hours and a 6.4 is even easier due to the cab bolts come out the bottom.
The DPF is an issue that can be "fixed"
I say go for it, and just make sure you delete the egr as soon as you can and you should be ok, and I am sure you'll love the truck. Good luck.
As my "call sign" might say. I like the F series. But the expression goes. ( if it has T*** or tires you are going to have problems out of it ). I sold my 97 with the 7.3 to a guy that offered me alot of money for it. In my opinion one of the best trucks ever made as far as a overall truck with one exception. The lack of a 3rd or even 4th door on the extended cab model. My 2001 with the 7.3 has 300,000 plus and still pulling hard. I have a 2008 with the 6.4 Auto 4x4 ext. cab and it will run circles around a 7.3 But it is still a truck and not a corvette. It pulls the 29 with ease and any piece of construction equipment I can load on the 12,000 lb. trailer. Both pulling and braking are just fine and I like the ride and the cup holders are in the perfect spot. Yes it has had issues over the last 136,000 miles what car or truck doesn't. #1 Brakes. Ford needs a better design that with stands the work load on trucks. The design of the coolant lines... "who is the idiot that thought that up"? Yes the DPF is coming off soon. There is nothing worse than your truck looking like it is going to blow up when the Burn-Off kicks in and your milage drops before your eyes. But it is a very nice truck. IMO. But the truck is quiet, comfortable on long trips and plenty of bells and whistles for me in the Lariet. But do your homework. Has the engine compartment be worked in alot? i.e. tool marks, cutting and removing or adding after market things that have led to a maintenance issue. Also get under the truck and look up. Is there any rust? Fender wells, brake lines, frame ect. Or hopefully it was undercoated when new. Buy used, Buy stock. Hope my opinion helps.
Dang! That is doing it right!
My old work truck blew up last fall 08 6.4 F-250 with only 118k miles bone stock and hardly towed anything, Just drove it. EGR always had issues, DPF system is terrible, it gummed the motor up and stuck a valve which cracked a piston. The stealership figured that out after replacing an injector and coolant hose for $1800....no refunds! Would only missfire at idle and dealer said it was only small crack and to drive it until it has a real problem. Apparently with a Ford that takes 3 days. On day #3 after picking it up, it wouldn't move out of its own smoke and had visible blow-by coming from the hood.
Our 09 6.4 F-350 service truck that goes across the country on the highways showed up with cracked/broken rocker arms at 180k miles. $3400 later the stealership had it fixed but died on the highway 6 miles from town after picking it up.
Both trucks were extremely well maintained with Rotella and religious service and scheduled maintenance.
Now I have a friend who loves the 6.4. Removes EGR and DPF, tunes the crap out of them, and hasn't had an issue for the past 3 that he has had. Go figure the stock ones blow.
stock 7.3 F250..231k miles...never an issue. Change the oil religiously....Looks like showroom still. Always under cover.....But I am anal with it......Pulls a 38 Top Gun anywhere I want.....hate to sell her, but going to F650 for Poker Run circuit.......hopefully I get as lucky with the F650 Cat..........
