Class 5 hitch up grade
Old 04-11-2016 | 06:12 PM
bck's Avatar
bck
Charter Member#568
I see what you mean. That's a huge difference. Doesn't even look like they're for the same truck.
Straight bottoms and flat decks
bck is offline
Old 04-11-2016 | 06:18 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I know, the factory GM hitch looks like it belongs on a Tundra or something.
Sydwayz is offline
Old 04-11-2016 | 06:43 PM
F-2 Speedy's Avatar
Thats the hitch it pulled the shuttle with
F-2 Speedy is online now
Old 04-11-2016 | 06:47 PM
Originally Posted by 33outlawsst
Curt class 5 on ebay 219.00.................Amazon 168.00 free 2 day shipping, thanks for the plug info ^^^^
Thats where I got my Curt Class V, on amazon. Paid around the same, it was for a chevy though. Anyhow, it fit great, and much beefier than the stock piece of crap. I also got a solid steel forged drawbar, and a 25k lb rated ball from the farm store. The 25k lb ball was like 25 or 30 bucks I think.
MILD THUNDER is offline
Old 04-12-2016 | 01:32 AM
Originally Posted by Sydwayz
Also, you will also have to find another solution for your trailer hitch wiring location.
On each of my trucks, I have drilled (with a metal hole saw) to the left of the license plate, and installed one of these:
https://www.etrailer.com/Wiring/Pollak/PK11893.html
Mounting through the bumper improves your rear clearance, by moving that vulnerable part up to a protected area. When you drill through the bumper, make sure you paint the edges of your cut with POR-15 or another rust preventative. The flange of the electrical connector will cover the paint.
Exactly the same one I used and where I put mine.
I got everything at Eastern Marine. Curt Class 5 (2") Extra Duty
Griff is offline
Old 04-12-2016 | 12:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Here is a great thread with a how-to and them some. One guy even integrated an RCA-jack for a trailer backup camera.
http://www.chevyavalanchefanclub.com...t=;boardseen=1
I've done the exact same process on 1 Avalanche 2500, 2 Chevy HDs, and 1 Ford Superduty.
I also like to run a lightbar on my trucks, under the tailgate. This is a great time to either splice or buy/add connectors to install the lightbar. Due to damage or for whatever reason, I've had to replace lightbars a few times, so it makes it much easier to swap them out when you add in a 4 or 5 wire flat connector under the truck specifically for the lightbar.
Sydwayz is offline
Old 04-12-2016 | 01:05 PM
carter38's Avatar
Get the curt commercial and be done with it rated at 20K and bolt on then you can keep upgrading boats and not the hitch lol.
carter38 is offline
Old 04-12-2016 | 02:30 PM
bumper connection is awesome. Just put a reese titan on my truck and was looking how to better mount the connection. fyi titan rated for 18k, bigger tow bar and bought a 20k ball.
Thanks.
grapeape93 is offline
Old 04-18-2016 | 10:46 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
A buddy just told he he has a brand new Putnam XDR true Class-V hitch, never installed for a 2006 Ford F-350.
Only issue is it's stuck in his lake rental house, and he won't be getting to it for a few more weeks. If anyone wants it, shoot me a PM and I'll help y'all out.
I have a Putnam XDR on my Ford F-350. and it's a fantastic hitch. (Putnam is now out of business.)
Sydwayz is offline
Old 04-18-2016 | 10:59 AM
F-2 Speedy's Avatar
got mine installed, a little challenging by yourself, I just blocked it up on my floor jack and wheeled it in place
