Trailer: Bow Stop Or Bow Roller? >
Old 04-15-2016 | 09:52 AM
Originally Posted by thirdchildhood
Bow rollers seem notorious for scuffing the bows of boats. Should I replace mine with a bow stop like this one from Overton's?
I have the one in the bottom picture. Holds up well and no marks anymore
class6 is offline
Old 04-15-2016 | 02:03 PM
Originally Posted by BajaDan
Try replacing the *** with the word ***************. Now if this doesn't go through I will start believing in an OSO conspiracy theory. And I just sent them money too.
No conspiracy, they just don't like competition. They will audit/remove negative posts/threads about site sponsors also. They are a business and in it for the money. Still lots of great info and members but they will censor what they wish.
As far as the Bow stop vs roller I would definitely go to a bow stop. It makes loading the boat easier plus the benefits of not scuffing.
baywatch is offline
Old 04-15-2016 | 02:23 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Dump the roller altogether. The best you can can do is switch to the split Bow Stops.
http://www.offshoreonly.com/forums/t...nch-stand.html
http://www.offshoreonly.com/forums/f...-my-fever.html
http://www.offshoreonly.com/forums/g...p-trailer.html
Sydwayz is offline
Old 04-15-2016 | 08:43 PM
Originally Posted by Sydwayz
I read all those threads and the Myco solution looks like more than what I want to get into right now. Also when I winch the boat up it does put some load on the front roller which helps support the boat. Looking at it I'm pretty sure the roller isn't turning so the roller mod might be my best bet now. I will know more tomorrow.
thirdchildhood is offline
Old 04-16-2016 | 07:12 PM
The roller is not turning! I'm going to try BajaDan's roller mod.
Old 04-16-2016 | 08:17 PM
Usually what happens is the bolt bends and then won't spin. Happened on my PQ trailer. When it turns all will be good.
Pwraddr is offline
Old 04-16-2016 | 09:28 PM
tcwcar's Avatar
Joe
I changed mine from the roller type, it always marked the bow, I bought the rubber blocks from myco they were about $40 each and made my own bow stop.[ATTACH=CONFIG]554242[/ATTACH][ATTACH=CONFIG]554243[/ATTACH][ATTACH=CONFIG]554244[/ATTACH][ATTACH=CONFIG]554245[/ATTACH][ATTACH=CONFIG]554246[/ATTACH][ATTACH=CONFIG]554247[/ATTACH][ATTACH=CONFIG]554248[/ATTACH][ATTACH=CONFIG]554249[/ATTACH][ATTACH=CONFIG]554250[/ATTACH][ATTACH=CONFIG]554251[/ATTACH]
Attached Thumbnails Trailer: Bow Stop Or Bow Roller?-100_5226.jpg   Trailer: Bow Stop Or Bow Roller?-p4170014.jpg   Trailer: Bow Stop Or Bow Roller?-p4190044.jpg
Trailer: Bow Stop Or Bow Roller?-p4190055.jpg   Trailer: Bow Stop Or Bow Roller?-p4240076.jpg   Trailer: Bow Stop Or Bow Roller?-p4240077.jpg
Trailer: Bow Stop Or Bow Roller?-p4240079.jpg   Trailer: Bow Stop Or Bow Roller?-p4240080.jpg   Trailer: Bow Stop Or Bow Roller?-p4240086.jpg
Trailer: Bow Stop Or Bow Roller?-p4240088.jpg
tcwcar is offline
Old 04-16-2016 | 09:36 PM
The rubber blocks are nice but I think the roller will be fine for my boat when it turns with the weight going up and forward. The fix is really simple too.
Old 04-16-2016 | 09:48 PM
tcwcar's Avatar
Joe
[ATTACH=CONFIG]554280[/ATTACH]Sorry here's the finished product, can only post 10 pics at a time, I made it adjustable and kept it on the gelcoat and not on the painted sides.[ATTACH=CONFIG]554279[/ATTACH]
Attached Thumbnails Trailer: Bow Stop Or Bow Roller?-p3230017.jpg   Trailer: Bow Stop Or Bow Roller?-pb080005.jpg
tcwcar is offline
Old 04-17-2016 | 06:37 AM
That's a lot more boat than mine! Looks nice, I like the yellow & white . My concern is that as I winch my boat up the last few inches it comes upward and forward to support the weight of the bow a bit. With that set-up it would be trying to slide against the rubber blocks. Did I mention I like the yellow and white? (in the one pic it looks like the outboards are on it!)
