Thoughts 2nd gen "Dodge ram 3500" >
Old 11-18-2017, 07:40 AM
The FASS is just a good lift/fuel pump setup with filters mounted on the unit. It is adjustable with in a range depending on the delivery requirements needed. So it's just a good pump. Remote mounted for easy service. the Bosch VP44 is the injection pump that came on the motor. And it's a good pump. And if it hasn't crapped out by now. It probably won't.
class6 is offline
Old 11-18-2017, 07:55 AM
I own a excavation co. I own and take care of nothing but Diesel engines everyday. That same motor I have had in service and personal trucks, Equipment , generators and pumps. It's a dependable motor with basic maintenance. Parts are fairly cheap compared to the newer 6.7. The 6.7s have a pump and rail system with more electronics to add to the misery of ownership. IMO the 5.9l 24V is a great motor. What to look for on the truck 1st. Would be rust. Body repair and color you like. And does it need tires. If you really want to check that motor. Go to a caterpillar dealer and get a oil sample kit and send it out for analysis it takes about three days and I could tell you a lot
class6 is offline
Old 11-18-2017, 08:14 AM
Do the late model steering linkage upgrade [ knuckle to knuckle link ] & Rehead steering box , nice upgrade .
575cat is offline
Old 11-18-2017, 06:05 PM
lucky strike's Avatar
We have a 1998 Dodge 3500 4x4 Dual wheel extra cab 5.9 12 valve diesel. White with blue interior with 80,000 miles. Super clean I would part with.
We just bought a 2015 Ford f 350 4x4 dual wheel crew cab king ranch to use for poker runs.
lucky strike is offline
Old 11-18-2017, 08:43 PM
scippy's Avatar
Hey Lucky how can I get some more info and pics on the '98?........Scippy
scippy is offline
Old 11-18-2017, 09:23 PM
Here are a couple, don't have many. However, it's a 1996 though, not a 1998.
Lucky Strike Jr is offline
Old 11-18-2017, 09:26 PM
2nd.
Old 11-18-2017, 09:53 PM
scippy's Avatar
Lucky sent you a pm.....thnx, Scippy
scippy is offline
Old 11-18-2017, 10:05 PM
Did u send it to Jr or me?
Old 11-18-2017, 10:17 PM
Default Old truck
Old truck
