Triple verses Duel
Thought on new aluminum triple axle verses duel axle for Baja 26 Outlaw. Boats been on duel steel.
Triple axle verses dual
I wouldnt see a need for a triple axle trailer, just more weight you have to pull.. I just bought a 10k tandem axle trailer for my 29 fountain and it is more than enough.
Dual will be fine as a triple would be overkill for a 26 IMHO. I have double axle under my 35.
That boat does not need 3-axles. Why subject yourself to limited mobility, additional maintenance and extra tires to blow/replace?
Dry weight of the boat is in/under the 5K lbs range.
Good tandem is the best trailer as a tri is just going to chew up tires. (hell, you can efficiently pull a 36 on tandems if it's matched properly.) Tri axles have their place -your boat isn't one of them so save your maintenance/upkeep $$$ budget for buying a high quality tandem from the start |
I replaced my triple 3500# axles (10,500#) out for dual 6000# torsion axles (12,000#) on my 30' Panther. Best trailer decision I have ever made.
I tore up tires on my triple making tight turns. https://www.offshoreonly.com/forums/...ler-axles.html |
Dual all day long, easier to maneuver, less tires to worry about and at 26 feet you really have no need for triples. Back a triple up and make a sharp turn, you will cringe at what those tires/axles do.
dual
My triple aluminum trailer floats when backing into water with no boat on it. Had to add lead weights to keep it from floating.
Dual axle is more than enough for a 26 OL.
Duel for sure. I had a duel under my 29 Outlaw w twins from new- was always losing tires - they were 15" wheels. Almost bought a triple but instead got a new one w 16" tires. Could get much better tires and never had a problem again w rubber. But now i hear they have 14 ply for 15" wheels so problem solved.
dual
Is your dual trailer having a duel with another trailer?
i agree with most here,,,you dont need a triple for 26 foot boat,,,reason for more axles is handle more weight
| All times are GMT -5. The time now is 10:57 AM. |
