EOH Brakes not working
Old 06-13-2023 | 04:19 PM
My two cents. When I bought my EOH trailer, brakes worked fine until a couple of weeks later. Found out my controller wasn't EOH compatible & it couldn't handle the amperage. Put an EOH compatible controller on & it still functions 4 years later.
smashm is offline
Old 06-30-2023 | 09:03 PM
Update to the story... Back at the lake this weekend and as mentioned in a previous post I do have power at the 7 pin on my truck. I connected the brake harness today and when you manually move the brake controller I can hear the pump kick in, I can also hear it when the brake pedal is pressed. The the pump is working but I still have no brakes on the trailer. Any suggestions on where to go from here?
bigredbaja is offline
Old 06-30-2023 | 09:30 PM
Air in the line? Low on fluid?
underpsi68 is offline
Old 07-01-2023 | 09:49 AM
Checked brake fluid still full, Bleed the brake lines with the controller held over to 5 its highest setting. Still no brakes. A friend suggested the seals in the pump may have deteriorated to the point it cant build enough pressure could that be the issue? System is a Titan and its 15 years old. Bleeding brakes with the controller set at its highest point I would think would be the maximum amount of pressure to the caliper.
Old 08-09-2023 | 12:52 PM
Had similar issue. Check tow vehicle trailer power fuse.
WhiteLightning is offline
