Surge Brakes to EOH Conversion
Old 05-17-2024 | 04:24 PM
Default Surge Brakes to EOH Conversion
Guys,
I'm thinking I want to convert our surge brake trailer over the EOH. Anybody ever done it? What all is involved? In my mind, I'm immobilizing the surge brake sliding assembly.... Somehow.... (I have some ideas), mounting the electric-hydraulic actuator, connecting the brake line, and bleeding the lines. That about it?
Thoughts?
Thanks. Brad.
Brad Christy is offline
Old 05-17-2024 | 04:30 PM
Guys,
Thoughts?
Thanks. Brad.
It is very easy, like you said you have to either switch out the coupler or weld it solid as i did. Install the actuator where it is convenient (I, suggest, make sure it is above the water line) install all the wiring and brake line, fill bleed and you're done. Make sure to check if your truck is compatible with the EOH or you may also need a control unit.
1Zoom is offline
Old 05-17-2024 | 05:37 PM
Zoom,
I’m not real fond of welding if there’s a less “destructive” way of immobilizing the surge slider. I was thinking of making a linking bar to install in place of the shock dampers that are on it now.
The truck was electric ready from the factory. I’m good there. The wiring for the connector I can handle. I was thinking about mounting it on top of the coupler, directly above where the master cylinder is now. Might even be able to use the mounting holes with an adapter plate, which I could make.
Any recommendations on electric actuators?
Thanks. Brad.
Old 05-17-2024 | 06:46 PM
I went with hydra star kit for my disc brakes.
Hydrastar® MARINE Electric Over Hydraulic (EOH) Trailer Mounted Brake Actuator Plug'n'Play Complete System with Controller Adapter Module (CAM) - Hydrastar (hydrastarusa.com)
PA.WOODCHUCK is offline
Old 05-17-2024 | 08:17 PM
I also did the hydra star. Went with their plug and play kit because I hate wiring. I just replaced the coupler and sold the surge unit. Mounted the hydra star just behind the coupler on the tongue as that's where my brake line came out. No regrets, the trailer brakes much better and I dont have to deal with that annoying surge thud anymore.
anger mgmt is offline
Old 05-17-2024 | 08:23 PM
Just buy a new coupler. Not worth the time making it work if you don't want to weld it.
underpsi68 is offline
Old 05-17-2024 | 09:01 PM
bencini231's Avatar
It's super easy to do. The Hydrastar will be your best choice to go with. When I did my conversion I bought everything individually, including a new bolt on coupler and saved around $150 on parts vs buying the kit. Basically all that is needed is a break away switch, battery, Hydrastar unit, Ford/Chevy adapter if needed, seven way plug with cord and a junction box. Super simple to mount and connect everything in one afternoon.
bencini231 is offline
Old 05-17-2024 | 09:20 PM
UnderPSI,
Describe “new coupler”…. Does it involve cutting and welding?
Thanks. Brad.
Old 05-17-2024 | 09:22 PM
PA,
I found a thread on TheHullTruth that linked to the 1600psi version of that one. We’re 7Klbs boat and trailer. Is the 1000psi one OK?
1600psi HydroStar
Thanks. Brad.
Old 05-18-2024 | 03:24 AM
Veteran: Navy
You want the 1600 psi and a new coupler. Have had mine for 1 year and 4 days. Couldn't be happier. Went to Advanced auto for the Flex brake line
https://www.etrailer.com/s.aspx?qry=...+Bolt+On+-+21K
http://www.etrailer.com/s.aspx?qry=HYDRASTAR
AmiableDave is offline
