Bought engines today VV >
Old 08-02-2009 | 05:33 PM
  #741
Velocity Vector's Avatar
Crazy Energy
Originally Posted by DKerns
VV, glad to hear you are out enjoying that thing like it is meant to be enjoyed!!!!
Thanks D, it reminds me a little of a co-cart with to much power. Like the cart I built in the early 70's we put a 350 honda motorcycle engine in it, crazy!!
Velocity Vector is offline
Old 08-03-2009 | 08:41 PM
  #742
Originally Posted by Velocity Vector
..... the boat she stood up and shot out of the water like a missle. It was fun to say the least..
Like the Man says ........................ "Excitement Comes Standard!"
Spare shorts .......................... would be an option! Plus 2 bucks for XXL.
RaggedEdge is offline
Old 08-03-2009 | 09:24 PM
  #743
1HYPER1's Avatar
You just need to know how to fly it its like an 18 foot Allison on steroids
1HYPER1 is offline
Old 08-03-2009 | 10:14 PM
  #744
Are you really coming? cool!
Well,,,i almost was there .LOL
If the engine guy from my buddy would of done what he said then we would of been there.
But instead of completely dressed engines we got there friday to pick them up and drop them in ,,,,,,haha....we found 2 longblocks with wet paint sitting there and 100's of parts with most of the bolts missing. COOL
But ,,,,,it is what it is....engine builders. LOL
I will see you guys next time. PROMISS
DareDevil is offline
Old 08-03-2009 | 10:24 PM
  #745
Crazy Energy
I can see it's going to take some practice, Sometimes I just have to shut it down and start over...I need to change my trim pumps to K-plane pumps I think?. These are so fast with the longer 380 plates any more than a touch of the switch and your doing tripple toe loops on a trampoline. It's almost unsafe. I may even try the 280's again and see. I took my flush kit off the sea strainers and plugged them today to see if it was leaking sucking air, for some reason I am not getting a whole lot of water pressure since the rebuild. Looked at the impellors, they looked good, I pulled the water pressure gauge line off and the gauges are working with pressure applied. Last trip out we had 10 psi cruising 60 then later in the day it read just above 0 psi. When I ran it hard for a distance the temp was around 180 and 140 while cruising. The Sportmasters have the lower water pickups. We installed pressure relief valves on the strainers because I was thinking I would have a lot of water pressure. Any thoughts besides external pickups?
Old 08-03-2009 | 10:32 PM
  #746
Crazy Energy
Something tells me you been there...I can sober a guy up in a hurry with this thing...tight lips and white knuckles a must.
Old 08-03-2009 | 10:39 PM
  #747
Crazy Energy
Well I missed you guys, maybe next time. I was hopeing you could drive mine. I'm really wanting to see the No Reservation 41 Apache too. That boat is a labor of love to say the least.
Old 08-04-2009 | 07:10 AM
  #748
You can slow the pump speed down, did it on mine/Hypers.
Two ways ............. Change out fluid for heavier weight, old racer trick. Or, my method, reduce size of orafice comming out of the pump. Easily done with a couple brass fittings and some Holley jets. Beauty of the jet deal is you can adjust the pump speed!
Remember what I told you! Know your tab setting, set it around 70 - 80, don't F' with it at higher speeds. It will bite you! From there up trim only. Mark the tab indicator for neutral, run it up to speed, slow down, change it, then go back up until you find the right setting.
One other thing you could do is to get rid of the chitty little steering helm the factory uses. I had a 125 cc helm in mine, much quicker reaction, makes it far easier to stay on top of the chine walking at speed.
You could fly Hyper down to Oakleyhomer to learn ya how to fly it, I hear he crushes big Fountains in any size water!
Old 08-04-2009 | 11:41 AM
  #749
Crazy Energy
One other thing you could do is to get rid of the chitty little steering helm the factory uses. I had a 125 cc helm in mine, much quicker reaction, makes it far easier to stay on top of the chine walking at speed. Did you reduce at the pump or at the tabs?
I'll try the Ragged reduction method. Like I said about the school, nothing will replace seat time....Thanks. Did you reduce at the pump or at the Planes
Old 08-05-2009 | 09:38 PM
  #750
Next time i am up there i show u what your boat can do !!!!
Untill u scream in my ears. LOL
PROMISS
