Bought engines today VV
#751
I can see it's going to take some practice, Sometimes I just have to shut it down and start over...I need to change my trim pumps to K-plane pumps I think?. These are so fast with the longer 380 plates any more than a touch of the switch and your doing tripple toe loops on a trampoline. It's almost unsafe. I may even try the 280's again and see. I took my flush kit off the sea strainers and plugged them today to see if it was leaking sucking air, for some reason I am not getting a whole lot of water pressure since the rebuild. Looked at the impellors, they looked good, I pulled the water pressure gauge line off and the gauges are working with pressure applied. Last trip out we had 10 psi cruising 60 then later in the day it read just above 0 psi. When I ran it hard for a distance the temp was around 180 and 140 while cruising. The Sportmasters have the lower water pickups. We installed pressure relief valves on the strainers because I was thinking I would have a lot of water pressure. Any thoughts besides external pickups?
The boat willride much better with the short ones.
#752
Crazy Energy
I bought a 3 bank ProTech 1240i Battery charger right after I bought the boat had a guy here in town install it. I noticed it wasn't working the LED lights weren't on. I took it out and went inside and found a fuse blown. I had two batterys and added another battery on the re-rig and it was not hooked to the charger and none of the batterys had buss fues installed to the charger. So I added inline buss fues on each battery going to the charger. She's working fine again now...
#753
Did it at the pumps where the lines hook up. If I remember right it was a male to female fitting then I threaded the inside of the fitting to accept the Holley jets, hook the lines back up and bingo ............... Slow!
Get Hyper to look or take a pic and send it to you.
#754
#755
Crazy Energy
Today I am moving my water pressure lines from the block to the intake manifolds, they keep getting trash in them from the block position. That was fun reminded me of the Tommy Boy movie...Fat man in a little coat except this time fat man between 2 big blocks...I could barley reach to put plugs back in the blocks...
#756
Crazy Energy
#757
I awsume you gonna burn up the pump after a wile.
Put the 280's back on,,the reason why u think its faster is because u already hit the water when they are up.
the water brakes @ the end of the hull and splashes against them in the up position .
the bow can not lift right.
I HAD THE SAME HAPPENING ON MY BOAT,,,and put the 280's back on.
It realy only makes sense if u have boxes.
Becasue now u get more stern lift.
#758
Don't think so, it's a closed loop system, think that I only did the one side. What goes into the ram is equal to what comes out.
If Bill would get on the stick here he could even check and give you the jet size that was used.
#760
Crazy Energy
Sounds logical to do it on one side now that I think about it. I bought 4 SS hydraulic needle valves rated at 3000 psi. each for trim and tab pumps. The pump puts out 2600 PSI. One pump is always a little faster than the other, I'm thinking I will have more control of each pump with valves. I can slow one down to match the speed of the other so they will go up and down at the exact same time. Then adjust both for the speed it goes up and down. With this set-up I will have more control don't you think? The valves are 75.00 each but I picked up all 4 of these for 40.00 on ebay. I will let you know how it works out. I found this pdf file on trim pumps you might want to save for future reference....
http://www.boatfix.com/merc/Servmanl/6/6A5R3.PDF
