Any Velocity 260 Owners Interested In Mod's ????
#101
I've already called them to ask that same question............Quote: No patterns are already available for the Velocity......
So that means you'll have to trace out your existing platform and submit that for them to cut the pattern from. I'm not making any sudden moves as I'm still on the fence with a prior "TRANSOM SOOT" issue that if not corrected by the reflash from Merc would surely do more harm than good on the SEA DECK material. I'm waiting to get out again and validate any changes to the soot problem but weather here has been horrible.............
#102
I don't get much soot on the VR 1 and it is a molded on platform . I am thinking seriously of doing this sometime this summer.
Hopefully your soot problem is resolved. My 1998 used to get quite a bit of soot on the transom, after having the ECU massaged by Precision Marine it was pretty much resolved.
Padraig
Padraig
#103
Padraig
Padraig
All I can do is wait it out.
#104
Got my sample pack from SeaDeck, pretty cool stuff. With using this product, it's all about the application and prep since it's adhesive backed, very sticky stuff meaning once it's down, it's "DOWN" !!!!!!!!!
One thing that comes to mind is the swim/boarding ladder bolts, would have to modify them to get the heads below the surface, i.e. flat head screws counter sunk into the platform or you'll get the screw head bulge in the SeaDeck, I tried this with one of the samples and it didn't look good at all. My other concern is that if using flat head screws, it put's quite a load on the screw heads in the platform material by not being able to use a flat washer to distribute the load......don't know if that's a potential problem or not. Once you apply the SeaDeck material, there's no going back to tighten and hardware under it since you can't access the screw heads, guess one could epoxy in the screws to keep them from rotating.
Open for thoughts, comments and opinions.......................
#106
#107
LOL. Picking the VR 1 up, Monday, I know the 280 is different but will give it a hard look and but on my thinking cap.
I wonder if you could carefully cut out some of the seated on the adhesive side where it contacts the faster for the ladder? Just enough so that it lays flush.
#108
, just a passing thought.
#109
This is just a thought...............Not that I'm going to do it but, but I'm always looking for a used welded aluminum "TUBE" swim platform (Baja style) to maybe replace the Velocity OEM one some day, a little weight savings and far easier to keep clean as long as it's not white......
