Any Velocity 260 Owners Interested In Mod's ???? >
Old 03-22-2016 | 09:38 AM
  #71
Thanks for your input.
The tin can prefilter "WAS/IS" called out for my current motor. That's why I've replaced it with the Aeromotive unit. I agree that the plumbing is not the most free flowing, but it'll do for now as I too had thoughts about something a little more free flowing before the boost pump but space limitations only allow me to go upwards and I didn't want to do that. May opt to eliminate the 3/8" hose and go full 1/2" ID hose but it still ends up being restricted due to the boost pump fitting being 3/8 hose. From what I saw in the old tin can filter, I don't want any of that getting into the boost pump. It looked like the shavings from when they hole sawed the tank at the factory. Motor will not see any power increases as I'm past that point in my life and have decided to slow it down a bit and enjoy the comfort aspect of boating. So I'm coming from a 104 MPH Tunnel to a 70 MPH Vee......yeah, I'm like'n the comfort level allot......LOL !!!!
90profx is offline
Old 04-01-2016 | 04:09 PM
  #72
Glad to see you're enjoying this boat! I'm the previous owner of it.
These are some photos I managed to find a long time ago, before I owned it. The first thing I did when I got the boat home was get the flames off of it!
SnailblazerSS is offline
Old 04-01-2016 | 04:14 PM
  #73
What I did while owning it:
removed the windshield
tabs
stereo
GPS speedo
extra batteries and the charger
bblades prop
brand new tires and disc brakes on the trailer right before i put it up for sale.
Old 04-01-2016 | 04:19 PM
  #74
Old 04-02-2016 | 03:54 AM
  #75
Jarad,
I can blame you one bit for the flame removal, had the flames still been on the boat, I wouldn't have bothered to look at it let alone bought it, that was a dumb idea to put those on right along with the out of place looking way to tall windshield. I'm going to assume from the pics the boat may have come from out west ?
Obviously you can see I've made some changes as well, as for one, I didn't like the stereo in the cuddy so it got moved, added 2 subs and mono block amp, removed the existing cabin LED's and replaced with more and brighter lighting, dual engine hatch actuators, hydraulic steering, 3 new Optima batteries, Blue Sea ACR charging system with all new battery cables, resealed the drive, changed to new exhaust tips, glassed in new braces in the engine hatch . Still thinking of adding a low profile windscreen, just can't get past the bend me over price..... There was allot of corrosion on the drive, did you keep it in the water allot ?
90profx is offline
Old 04-02-2016 | 09:35 AM
  #76
The flames must have been an 03 thing as mine has them and I mistakenly thought they were vinyl when I bought it. I would love them gone, how did you remove them and did they leave shadows?
Thanks,
Rick
Powerquest230 is offline
Old 04-02-2016 | 11:49 AM
  #77
It's gonna take an unreal amount of wet sanding to get them off. And "YES" there will be shadows, but only you would know that as they're almost invisable to anyone else. I would have paid someone to remove them as it's gotta be a killer in labor.
90profx is offline
Old 04-03-2016 | 08:15 AM
  #78
Thanks,
Rick
oh it was a bear. I used a citrus based paint stripped called citrustrip. it softened the paint up enough to be able to scrape it up with a hard plastic scraper but didn't harm the gelcoat. I did not want to sand all of that. It did leave ghosting, and no one would see it unless they knew where it was. I had to look for it to even find it. lots of hours of labor getting that all off. it took me three full days of work myself plus the help of three buddies coming over for 4-5 hours in the evenings.
Old 04-03-2016 | 08:17 AM
  #79
I ended up making my own scrapers out of some bare silicon PCB boards. the plastic scrapers got dull too quick.
Old 04-03-2016 | 08:20 AM
  #80
Jarad buddy, all I can say is you did a great job .....
90profx is offline
