Light Bulb info for 260 >
Old 11-26-2015 | 04:08 AM
Default Light Bulb info for 260
Cuddy bulkhead swivel lights, what bulbs are they and how do you replace them ?
90profx is offline
Old 05-02-2016 | 12:45 AM
DBO
Should a bi-pin or G4 base. Just pull pulb straight out. Sometimes one of the will come loose from buld and can be removed with plyers . Shut batteries off!!
DBO is offline
Old 05-02-2016 | 04:42 AM
Thanks DBO, that was an old post that nobody jumped on so I went ahead a just did it on the fly. Covered in my MOD's thread.
90profx is offline
Old 05-02-2016 | 07:23 PM
DBO
No worries. I just added some LED lights in my cockpit and getting ready to change out the bulds in the cabin. Found a good selection @ marineledshop.com for what it's worth. I woud post but guess I need to upgrade membership.
DBO is offline
Old 05-03-2016 | 04:50 AM
You can post pics at your member level, (same as mine).....
90profx is offline
Old 05-03-2016 | 11:21 PM
DBO
I can't figure out how to post pics. I don't see how to add attachments. Any thoughts?
DBO is offline
Old 05-04-2016 | 03:30 AM
You'll need to upload your photos to a site like "PHOTOBUCKET", once in there you can copy the entire "IMG" link and paste it into your post, bingo your pic has been posted. I'm sure there is a YouTube video available as well so look that up too.
Example below from Photobucket site:
90profx is offline
Old 05-04-2016 | 11:17 PM
DBO
Let me work on that.will post pics if and when I can.
DBO is offline
Old 05-10-2016 | 11:52 AM
DBO
Over the weekend i got the LED bulbs put in the cabin. LOOKS AWESOME !! I changed out the bulbs in the round lights ( two on the side wall,two directly above the cup holder) with blue LED. worked out great. I was also considering adding more lights to the cockpit as there is only one under the bench seat. I changed the bulb out for LED and WOW. No need to spend the additional time running wire and installing more lights. The new LED did the trick.:ernaehrung004 Still working on Photobucket so I can upload pics.
DBO is offline
Old 05-10-2016 | 03:41 PM
DBO
pics[IMG][/IMG]
DBO is offline
