496 Sea Pump Repair Kit $100
Just thought I'd share a repair kit for the 496 Sea Pump @ $100 vs a new pump at $700+
http://www.amarket.com/im496reb.htm |
I installed this kit over the winter. Original bronze housing was worn. Nice kit, laser cut stainless wear plates, shorter impeller to make up for difference in wear plates. Rubber consistency of impeller was same as oem Merc from the feel of it. First startup it visibly moved more water out the tips at idle. I'll do a long term review.
I sure hope they ship fast, just ordered mine yesterday. This kit was already in my Sea Pump from the previous owner, couldn't figure out where it came from (wasn't OEM that's for sure) till I did a web search and found it, my impeller failed me Monday. It's a great alternative to a new pump but wish I knew too what the life span was.
http://i177.photobucket.com/albums/w...t.jpg~original |
One other question, while I have the Sea Pump off/out should either of the 2 lines (intake & output) be flushed using a garden hose ? Any benefit to doing that at this time ?
Yes you must remove all hoses and find all the broken pieces of the impeller. They get stuck in the coolers and will affect cooling.
100% of the impeller pieces have been accounted for just in the pump disassembly (lucky me), just wondering about back flushing the fuel and power steering lines ? The Heat Exchanger is spotless.
Thanks |
Originally Posted by 90profx
(Post 4444866)
Thanks |
Back flush complete of entire raw water system, pump parts will be delivered today and heat exchanger gasket kit on Monday.................let the reassembly begin :party-smiley-020:
you need O rings to for the end caps bolt and stud and you need grommets for the crossover that the heat exchanger ports sit into.
Originally Posted by BUP
(Post 4446102)
| All times are GMT -5. The time now is 02:43 AM. |
