back in a velocity! >
back in a velocity!
back in a velocity!
Old 07-22-2018 | 05:24 PM
  #41
Motor is done and got fired up for the first time in the boat today. Dynoed right at 700hp on 87 octane. Everything from the bulkhead back is pretty much new. Entire engine, transom assembly, transom itself, and outdrive. Did closed cooling on this motor as well. Sounds killer, should be in the water next weekend
Bnbz28 is offline
Old 07-24-2018 | 06:24 PM
  #42
Originally Posted by 29 FOUNTAIN FUN
Awesome Looker.
wow😎😎
veloc410 is offline
Old 07-25-2018 | 09:05 AM
  #43
Originally Posted by Bnbz28
Motor is done and got fired up for the first time in the boat today. Dynoed right at 700hp on 87 octane. Everything from the bulkhead back is pretty much new. Entire engine, transom assembly, transom itself, and outdrive. Did closed cooling on this motor as well. Sounds killer, should be in the water next weekend https://youtu.be/OX4D3u-Rdnk
Wow! Sounds/looks great! That's alot of work completed right there. Good choice on the closed cooling. Makes system soo much better. Thermally stable, no corrosion.
Ryan00TJ is offline
Old 07-25-2018 | 09:54 AM
  #44
Yea we do a mix of salt and fresh water so with aluminum heads figured it was money well spent
Bnbz28 is offline
Old 07-25-2018 | 09:55 AM
  #45
And on the dyno making pull after pull the temp stayed 169-171*
Bnbz28 is offline
Old 07-25-2018 | 10:04 AM
  #46
Sounds and looks fantastic!
Padraig
Padraig is online now
