VR 1 ready >
VR 1 ready
VR 1 ready
Old 08-28-2018 | 01:42 PM
  #51
Originally Posted by Ryan00TJ
Pulled the boat to change a leaking circulating pump. Cleaning up the hull today. Looked at the pad. 12" wide. There is a centerline on the pad clearly visible. It is not centered on the pad running surface. 6.5" to port, 5.5" to starboard. While the pad bottom itself may not be offset to the centerline of the hull, the pad itself is.
what?? Never would have thought??
veloc410 is offline
Old 08-28-2018 | 01:44 PM
  #52
Was this your boat day 1.
veloc410 is offline
Old 08-28-2018 | 01:45 PM
  #53
Originally Posted by Padraig
I put the VR 1 in just before Memorial day weekend. Didn't get a chance to thourghly clean and wax as my Yukon had to go into the body shop. Poor baby sat on the lift, dirty and dull.
I pulled it out yesterday, washed,clayed,polishef and waxed it today. I am tired but happy. Will fill the gas tank and put it back im.
Padraig
How is it running??
veloc410 is offline
Old 08-28-2018 | 02:00 PM
  #54
Originally Posted by veloc410
How is it running??
Running good! How has your summer been?
Padraig
Padraig is offline
Old 08-28-2018 | 02:58 PM
  #55
It's been good . Poker run went good. Put on about 180 mi that weekend. Now just trying to get out as much as possible before it gets cooler
veloc410 is offline
Old 08-29-2018 | 01:02 PM
  #56
Originally Posted by BUP
watch the video. At the end of the video Mark is posting specs and speed. 75. 3 mph at 5400 rpms no way for a stock 496 HO pushing 5400 rpms , it revs limited at 5150 rpms. Kind of funny for me since I see so many 496's. Well not so much currently but in the past.
. https://www.youtube.com/watch?v=b635jyb4XAg
Could you remove the rev limiter via software, just for purposes of the test? That would be one way to post a bigger number, if the engine has the HP to push it.
motuman is offline
Old 08-29-2018 | 05:48 PM
  #57
Yes, the rev limiter can be raised if you can program the Merc PCM555. Whipple Superchargers and a few others can do this. No help revving a stock 496HO anywhere over 5150 rev limit. Power falls off big/fast after. Not to mention possible valve float as valvesprings are very weak.
Ryan00TJ is offline
Old 08-29-2018 | 07:39 PM
  #58
BUP
do not even bother to go over 5100 with a stock 496 HO - there is nothing there on those stock apps. Stay off the rev limiter as well. Only a couple can raise the rev limiter on a recal for PCM 555 but after the first 500 HO 496s were made even the crank is not forged just to bring that up on top of. Not any forged internals in a 496.
basically for the recals on PCM 555 most that say they can really are sending them in to the very few that can. I am looking into recaling as we speak to do it myself as well.
BUP is offline
Old 08-29-2018 | 08:23 PM
  #59
Interesting. I wasn't suggesting raising the rev limiter for anyone, except as a possible explanation as to how they hit 75 @5400 with a stock 496 HO in the video.
So this chart showing forged crank and rods on the HO is incorrect?
motuman is offline
Old 08-29-2018 | 09:09 PM
  #60
Some early 2001-2002 496 HO's had the forged crankshaft until GM Powertrain - GM quit using them in lieu of GM's own new pressure rolled fillet nodular iron special 496 crank (bean counter decsion). Its nothing like an earlier GM cast iron crankshaft, much better part and nitirided too.
The forged units are a bit stronger and lighter than the cast crankshafts but both are very capable of handling 600-700HP without failures.
496 connecting rods, they are forged rods, early ones with pressed pins the later ones with full floating pins. These rods are metric length in stroke (6.683") and will not interchange with 454-502 sizes because they also have a metric diameter pin (actually measures about 1.043") which is larger than the standard BBC .990" size pin. The metric 10mm dia. rod bolts are not as strong as good ARP 7/16" rod bolts.
Ryan00TJ is offline
