I need a bravo one upper yoke/input shaft
Hey Fellas, I'm looking for an input shaft/upper yoke. My coupler blew and chewed up the shaft. I swapped out the coupler and need a shaft for the drive. It's a 2006 bravo one drive with the u joint retainer clips on the inside face of the u joint portion of the shaft. It has 17 splines.
Anybody have a lead on a good condition used one?
I can find them new but in canadian dollars they're like $400. I'd rather a good used one for much cheaper.
Thanks!!
Thanks!!
I have one. 17 splines, 9.5". Inside U-joint clips.
I'm not sure what you mean by cup diameter. The U-joint is still attached and is in perfect condition. Shipping to Canada could be quite expensive as it is heavy but I am near the border in metro Detroit if that helps. $60 US + shipping.
If the U joints are in good shape that is a great deal. You could remove the U joint from the input shaft and then replace the caps for use later. An input shaft for 80CAD plus ship and have the other parts if ever need
