Go Back   Offshoreonly.com > Owner's Forum > Formula
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-15-2006, 10:46 AM   #1
wantsa311's Avatar
1995 Formula PC 34
Replacement Depth Finder
My depth finder quit working. It wasn't the original one and never worked all that great anyway, but now I've got nothing.
Has anybody had a good experience with a replacement unit? I'd prefer something that would mount in the stock location on the control panel.
wantsa311 is offline   Reply With Quote
Old 07-15-2006, 01:21 PM   #2
Charter Member #415
1968 Switzer Shooting Star,1967 Switzer Shooting Star,1963 Glasspar G-3
Re: Replacement Depth Finder
The unit Formula uses now says Teleflex,but it's just a Humminbird HDR 600 made in good ol Alabama About $100 . They used to use the Lowrance 3500,now it's the LST3800 that includes water temp,maybe $150.West Marine or BassProShops or most any marine supply house has them.I would go with the Humminbird,it's cheap.works well,and helps Alabama a little I suppose Get the one with puck transducer,it comes with epoxy to glue inside the hull.
Magicfloat is offline   Reply With Quote
Sponsored Links
Old 07-15-2006, 02:37 PM   #3
1989 Formula 206
http://www.mall24-7.com/item--Hummin...k--403990-1WWP
formula18 is offline   Reply With Quote
Old 07-17-2006, 08:16 PM   #4
wantsa311's Avatar
1995 Formula PC 34
Thanks for the info. Is there something special about the epoxy they use to glue the puck to the hull? I think I found my problem - the puck was just laying on the bottom no longer glued. I used some 5200 to re-attach it but it doesn't work as good as it used to.
Old 07-17-2006, 09:56 PM   #5
Charter Member #415
5200 will kill the signal. You can get 2 part epoxy at Ace Hardware or just use fiberglass resin and hardener,not 5200 or silicone of any type
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Depth Finder hdtvned General Q & A 3 08-08-2007 08:48 PM
Depth finder? groundsfordivorce General Boating Discussion 2 08-07-2007 08:50 PM
Depth finder help please dencam7 General Q & A 1 07-30-2007 01:28 PM
depth finder baja bailey General Q & A 15 07-25-2007 01:20 PM
depth finder speedchangesyou General Q & A 4 08-02-2005 02:33 PM
Search Engine Optimization by vBSEO 3.2.0
