I also have a painted myco with a swing away drive guard and aside from where the two mopeds rubbed the paint off up front the trailer is fine it sits on torsion axle suspension (a little more but worth it) I had the trailer lowered to match the stance of the dually I was towing with. The only upgrade to the trailer will be going to electric over hydrallic and adding brakes to the third axle.
How much was that trailer, sounds great:)
Jassman I paid 7k for it back in the spring of 98 I delt directly with MYCO and it was very easy. If i did a new trailer now I would do galvanized with fiberglass fenders and custom wheels. Or i would consider stepping up to a pressurized rail trailer that is sealed and painted to match.
Thanks ESSERMAN, Ill check into it, along with the aluminum ones, what is the difference if they are all welded, where is the trailer built better on say the Myco.
SSherman,
I saw on another thread that you might make the scope run. If our boat is done in time, we'll be there. It would be great to start seeing some ATs running together in the Pacific |
I just relized it is the same Weekend as the LOTO shootout i missed it last year and every year i have taken the thunder we have won our class so i am not sure what i will do I will let it just shakedown how it shakes but i will be in Havasu for the heatwave run (riding with jeffrey in speed racer)
ssherman,
I'll have to look you up at the heatwave run. I will probably be boatless by then as our current boat is for sale and has to go. |
| All times are GMT -5. The time now is 05:37 PM. |
