gps speedo help
Mine was broken when I bought the boat. My brother's was broken on his Fountain when he bought his as well...He just spent $200 I think for the new antenna and/or battery. I just bought a handheld GPS unit that I mounted to the dash. It gives me speeds/top speed recall and directions.
Here the new battery cost $3:90 Batterys plus has them you need to tell them to put the tabs on the battery.They said they would install it for $10.But I'am going to solder mine tomorrow.One my friends bring in his solder sucker solder pencil.I will let everybody if it fixes the problem.
Mines dead also. What a crap setup.I couldn't get the
proper battery so I tried soldering in a regular 3v wafer
battery. I still didn't work. I will get the proper battery
and install it next weekend.
Mine is located in the tall closet/TV-compartment just forward of the head. It's all the way in the back of the compartment.
The later model boats have them up in the gunwale forward of the shifter/throttle controls.
They are wired into the dash very intricately. You can cut all of the zip ties and pull the whole puck and cable out for repair.
OR
You can cut the cable to the puck leaving at least 2 feet of pigtail hanging off the puck. Once you have the battery replaced, you can splice the three leads back together. They are about the same as telephone wire.
OR
