gps speedo help >
gps speedo help
gps speedo help
Old 08-19-2009 | 07:11 AM
We ended up finding it behind the panel in the storage compartment behind the TV, why on earth would it be back there ? would it not be easier to mount it under the dash ?
I just replaced my antenna. Livorsi said it wasn't the battery but a short in the wireing so $250.00 later it works perfect. Alot of tie straps to cut and replace.
laszlo01 is offline
Old 08-19-2009 | 07:43 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Pat started mounting them behind the dash in the past few years. However, they are sensitive to radio equipment, other antennas, GPS, compass, etc. That's why they are placed up in the gunwale where you found yours.
This was also before anyone knew the puck had a battery that would need eventual replacing. The newer models do not have puck batteries per Livorsi.
Sydwayz is offline
Old 08-19-2009 | 08:00 AM
ACTIVESHACK's Avatar
Mine was behind the dash up high close to the deck mounted on a L-bracket. Real easy to get too and change. The bracket was even powdercoated blue to match all the outside stuff
ACTIVESHACK is offline
Old 08-19-2009 | 08:28 AM
boatfreak's Avatar
Well aren't you special. Mine is in the same place but on a plain metal bracket.
boatfreak is offline
Old 08-19-2009 | 09:14 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yeah, you paid extra for that.
Sydwayz is offline
Old 08-19-2009 | 10:32 AM
Probably so
Old 08-20-2009 | 08:27 AM
yzbert's Avatar
i have yet to have the time to find mine, but i do know it is not behind the toilet now.
i am getting tired of my son asking if we can go faster than 30 though.
yzbert is offline
Old 08-20-2009 | 01:57 PM
Remove the panel inside the cabinet under the Tv and it is back in there, kind of a pain but its in there.
laszlo01 is offline
