Winter Project >
Winter Project
Winter Project
Old 12-03-2009 | 05:03 PM
  #31
AIR TIME's Avatar
Originally Posted by laszlo01
Greg Reno at Kustom Marine and having Gellner Engineering do the heads and custom cams for the whippled 509's. I cant wait to see how it runs.
that should run nice with Dean doing his magic.
AIR TIME is offline
Old 12-04-2009 | 12:34 PM
  #32
Just talked to dean the other day and his words were they will be a killer set of heads, he is almost done with them. Can't wait to see the dyno numbers.
laszlo01 is offline
Old 01-16-2010 | 02:08 PM
  #33
Thunderstruck's Avatar
Finally getting moving on winter stuff.
Bilge needs some work!
Long time cult member.
Thunderstruck is offline
Old 01-16-2010 | 04:37 PM
  #34
#4 Main Bearing cap.
Old 01-16-2010 | 04:55 PM
  #35
Crank.
Old 01-16-2010 | 05:06 PM
  #36
Back of motor shows effects of the Key West run hose leak in '07.
Old 01-16-2010 | 05:11 PM
  #37
Parts for powdercoating piling up.
Old 01-16-2010 | 05:13 PM
  #38
I've got a lotta work to do.
How are all you guys doing??
Old 01-17-2010 | 09:48 PM
  #39
REMEDY's Avatar
Bearings don't look too bad from the pic, how many hours? are they aluminum back "P" bearings? I don't know what Merc uses. I use ACL coated by Calico in everything. Im might be rolling bearings into 2 HP500 carbed engines soon to get another year out of them and curious to see what they look like at 400ish hours.
REMEDY is offline
Old 01-18-2010 | 07:47 AM
  #40
I don't remember what bearings we put in last rebuild. I'll take a look.
Probably have 250-300 hard hours on the bearings so I'm changing them some other parts while the motors are out.
