-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Savage speeds? (https://www.offshoreonly.com/forums/active-thunder/290297-savage-speeds.html)
rssteiny 01-30-2013 08:13 AM
Originally Posted by Drock78 (Post 3858213)
I have a-2 imco lower if you want to try it out first...
Did your imco shortie pick you up and if so how much.
Drock78 01-30-2013 09:31 AM
I haven't ran it yet but I think Greg said 2 or3 mph if I remember right.
JUPITER PULSARE 01-30-2013 04:27 PM
Originally Posted by Sydwayz (Post 3851338)
Do you have a particular hull in mind already? 2004 and later will be a few ticks faster as the hull was tweaked a bit.
Actually, the early 28's came from the 31' Active Fish mold with a damned down to 28'. The boat bottom had more rocker, different strakes, and a very sharp deadrise at the bow. The later 28's came from the damned off Active Thunder 32 which was and still is a great running straight V hull. The top decks had to be adjusted to fit the newer style hulls that were based on the 32' bottom. Both were great running boats but the later boats handled better..
Crossett 02-14-2013 12:42 PM
Someone needs to build a 28 with a pair of Ilmor MV8 570's. Any clues on what that would run, price and speed wise? Maybe refitting an older 28 wouldn't be that bad....
*edit*
I guess the Ilmors are iron blocks. These guys are all aluminum...
http://www.mast-marine.com/product-view.php?id=396
