New AT 37 owner....need alittle help >
Old 07-03-2013 | 01:52 PM
  #61
Originally Posted by bonesmalon
I'm running 32 B1's Labbed by Cutting edge that's about where I'm at Trim it high and let it fly
How fast? What rpm?
MILD THUNDER is offline
Old 07-03-2013 | 02:44 PM
  #62
29 Hydro P5x with a slight lab finish 12% slip
laszlo01 is offline
Old 07-04-2013 | 07:30 AM
  #63
Macklin's Avatar
Originally Posted by EZEF350
what pitch where your 5 blades? 28 or 30?
I went with 29's so I could keep them stock. They were spot on.
Macklin is offline
Old 07-04-2013 | 08:01 AM
  #64
Originally Posted by MILD THUNDER
How fast? What rpm?
83 at 5300
bonesmalon is offline
Old 07-04-2013 | 09:53 PM
  #65
boatfreak's Avatar
Originally Posted by TDSTYG
I have a guy trying to sell a set of these at my lake? Will this help my 33? I've hit 91 once and 88-89 on most any day with stock 32
Are you going up to Boyne Thunder? I have a set of Hydro's that your welcome to try but I doubt you will be able to spin the all the way up. I think they are 33s so as I say I doubt you could spin them too high but you could still get a feel for them.
boatfreak is offline
Old 07-05-2013 | 10:13 AM
  #66
They say 30s on them or were they worked on to be 29s
Only saw between 52-53 at 3500rpm and ~57-58 at 3800rpm depending on water conditions.....but never saw 60pmh at 3500 since I took delivery ....so about 58hrs put on so far from me...184hr total.
Jluloff is offline
Old 07-05-2013 | 10:22 AM
  #67
Yup was the same i ran when was stock. boat liked them alot
laszlo01 is offline
Old 07-06-2013 | 10:28 AM
  #68
Macklin's Avatar
My bad! Receipt does say 30. Sorry bout that.
I think I remember Laszlo talking about his 29's, but the guy at Hydromotve figured I would need to go up to 30 being in the salt.
John, since you run in fresh, you should consider sending them in for labbing. You will want to get the Bravos tuned first. I had a local prop shop tune them and was not thrilled with the results.
Macklin is offline
Old 07-15-2013 | 07:37 PM
  #69
so we have the same year boat, and mine is about exactly the same as yours. at 3500 rpm my boat runs 51 mph and 60 at 4000 and tops out at 80 maybe 81 at 5200 w 4blade 32p bravo 1. so r you running 5 blades? brand? pitch?
EZEF350 is offline
Old 07-15-2013 | 08:18 PM
  #70
Macklin same issue here, cant remember if was 29 or 30 with final #'s. I will have to look... Either Hydromotive or BBlades both great shops...
laszlo01 is offline
