Sommer Thunder in the rain... :( >
Old 07-21-2016 | 08:47 PM
My old Sonic used to like to collect water in the forward compartment. I had considered getting some goldfish, but after sealing up the bow light {common problem with that vintage Sonic } all was good! I know unrelated, but funny, none the less!
509 SC is offline
Old 07-22-2016 | 07:18 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
My 26' Sonic was a mess up there too. I used to have so much water, it would hit the back of the speakers and throw out low notes from moving the cones when the music didn't call for it.
Sydwayz is offline
Old 07-22-2016 | 09:37 AM
sommerfliesby's Avatar
Originally Posted by Pwraddr
All the white silicone was from someone that tried to seal the hose on the wrong sized drain.
The new drain isn't as small as the original but at least now it is all sized correctly and can flow the amount of water without backing up.
[ATTACH=CONFIG]557509[/ATTACH]
[ATTACH=CONFIG]557510[/ATTACH]
[ATTACH=CONFIG]557511[/ATTACH]
[ATTACH=CONFIG]557512[/ATTACH]
I figured out that the size of the drain hose/cup was probably too small...and the problem was compounded by the HUGE amounts of water running off the roof. Towing home in the rain last weekend...I found my other problem was accurately diagnosed as leakage from the mushroom cleat. Gonna have to get in there with a big silicon solution...but for now...a towel will do!
sommerfliesby is offline
Old 07-22-2016 | 10:32 PM
It's not the cup being to small. It is the hose off the cup is bigger then the small drain. They put and adapter on the drain because it isn't long enough to go through the hull. Then the size is smaller than the hose. All I did really was replace the cup. Install new piece of 1/2 inch hose and install the proper 1/2 drain. Flows like crazy now. Not one drop.
Pwraddr is offline
Old 07-22-2016 | 10:42 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Just be sure that there is no way your bow stop is going to catch that drain protruding from the hull; especially when at a ramp that has different angles an attributes than you normally encounter.
Sydwayz is offline
Old 07-23-2016 | 09:53 PM
Haven't had any issues. Used several different ramps.
Pwraddr is offline
