need prop advise 25 tantrum
I recently bought a 1996 25 tantrum. The boat has a 502mpi bravo one with a 3 blade cupped 25 pitch mercury marage plus stainless steel prop. I'm running in the low 60's speedo not gps at 4600 rpm. I was wondering what props everyone is running. I think the boat should run in the upper 60"s and closer to 5000 rpm.Also I was can any one tell me what kind of bulbs go in the cuddy for the lights in the front. All mine were removed for some unknown reason.
Thanks for any help.
Chad
[email protected]
96 active thunder tantrum25
Chad
[email protected]
I never tried a three blade to compare max speed but Im currently running a Bravo I prop.
My boat handles very well with this prop.
As far as speeds I think your best bet is to talk to Pat and try to figure out how your boat was built, ie pleasure/F1 ect. Ive found quite a spread in the max speed (or what I was told) on the 25 depending on set-up.
Chad , I have a 1996 25 Thunder .It runs 68 at 5000 on the speedo depending on the water conditions. It also has the Mirage Plus 3 blade 23P. Mined uses the 64415 12v-10w Halogen bulbs from OSRAM. OSRAM is Sylvania in Germany . I called the 1-800 for Sylvania and they gave me Bulbtronic 1-800-654-8542 ext.469. Ordered the bulbs and they were sent right to me. Hope this will help you out.
rssteiny;
I think you had Thunder Dans old 25.
Keep in mind that boat was built as an F1 (Smith bros.)boat and ran an extension box. It has taken mine ('98) 550hp/565toruque to get the same results (mph) as you. Your old boat and Gordo's boat have left me baffled trying to set up mine.
BTW; congrats on your new ride.
???? Was a '96 under Pats watchful eye or was that the previous owner?
