Electrical Help >
Electrical Help
Electrical Help
Old 10-23-2007 | 04:48 PM
Tony Montana's Avatar
The BAD Guy
Ok update. I had time to look at it today and it was very simple. The battery was dead! So I put a new one in and as I am cleaning up I see the red light on the dash lit under one of the bilage pump switches. I raise the hatch and sure enough the staboard pump is running. I take a pole and tap the pump thinking it is stuck and still nothing. Then I notice that the hose used to drain the block is caught under the float switch.It must of ran and killed the battery. So I remove hose and the light shuts off. I guess last time out it got stuck under there. The pumps work off battery even when the battery switches are off. So now the puzzle is solved. Thanks
Tony Montana is offline
Old 10-23-2007 | 05:14 PM
cosmic12's Avatar
Just goes to show, Always start with the basics. Glad to hear you got it. Now get out and enjoy. Are you going to do the Thunder run to K-west?
cosmic12 is offline
Old 10-23-2007 | 05:32 PM
I wish my issues were that simple. I already checked the obvious stuff.
baywatch is offline
Old 10-23-2007 | 07:25 PM
The BAD Guy
Not unless your riding w/me and paying for the gas
Old 10-23-2007 | 08:10 PM
Darn that would be fun to do. I wish my schedule wasn't so hectic at the moment. I would be all about plunking down some coin for fuel. Maybe next year.
Our weather this weekend is mostly sunny and highs in the low 60's so this might be our last weekend of boating until next April. I guess that means I am going to have to figure out my electrical issue.
baywatch is offline
Old 10-29-2007 | 07:49 AM
I fixed my electrical issue yesterday. I opened up the dash and removed each panel light and then I isolated one by one until I threw a fuse. Evidently the panel light on the starboard voltage meter was tuching something it sholdn't have because after jiggling it a bit and plugging it back in everything worked fine. I now have panel lights, I am so excited.
Unfortunately, though I fixed the electrical issue, I had a new problem arise http://www.offshoreonly.com/forums/s...d.php?t=172111
I guess I won't be winterizing until I figure that one out.
baywatch is offline
Old 10-29-2007 | 03:53 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That's what credit cards and Christmas bonuses are for. Get on the sticks man!
Sydwayz is offline
BootyPirate
Chris Craft
2
07-11-2007 07:06 PM
Courtholl
Pantera
3
04-25-2007 02:41 PM
OldSchool
14
09-21-2006 09:42 AM
WILDTHING TAZ
5
03-10-2005 05:41 PM
